Old 02-22-2004, 01:37 PM   #1
ucmydust68
fuel
need pics of where your air comps. are
well i think i have a pretty good idea of where i want mine but would like to see some other options before i drill holes. please and thank you!
72 w/67 front clip
415ci
fuel injection
t56
air ride
18/20's
ucmydust68 is offline   Reply With Quote
Old 02-22-2004, 05:40 PM   #2
PrimeredThunder
Back from the Dead
PrimeredThunder's Avatar
I have mine temporarily installed in my cab behind the seat...its safe from the weather, but extrmemly annoying when its running. I usually run it when I'm not in the truck. I plan to re-mount it on the frame under the truck when I get a bigger tank. I know N2TRUX has his mounted on the rear framerail behind the tires right next to where his tanks are mounted. Sounds likea good idea, keeps the noise down. Heres my ghetto ride...
The only Carb that matters to me is the one under my hood!
Salem, Oregon
PrimeredThunder is offline   Reply With Quote
Old 02-22-2004, 11:55 PM   #3
phantom dually
Project92 SWB stepside
phantom dually's Avatar
Whats up with the tank??
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 02-22-2004, 11:57 PM   #4
ucmydust68
fuel
correct me if im wrong but i think that is a scuba tank, those things are really strong, not a bad idea and you can get them cheap because they can only be used for so many hours before safety says you have to get another. not bad primered thunder
72 w/67 front clip
415ci
fuel injection
t56
air ride
18/20's
Old 02-23-2004, 12:00 AM   #5
phantom dually
I beleive you can use a SCUBA tank for as long as it is pressure tested to Dot standards every 3-5 yrs or so.
Old 02-23-2004, 12:52 AM   #6
Prerunner1982
Prerunner1982's Avatar
if its on a 73-87, and you want it out of the weather, and out of suspicious eyes.. if you have dual tanks (or add one if you only have one) you could cut a tank open, (clean it, obviuosly) install tank and compressor in there, line gas tank with sound deadening material, and maybe mount a few exhaust fans to keep things cool.... sounds like a clean trick idea anyways... and if the compressor doesnt run for too long the heat wouldnt build up all that much.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 02-23-2004, 02:38 AM   #7
BaggedC10
Under construction!
BaggedC10's Avatar
Not a bad idea but the compressor(s) need to be in an open environment.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 02-23-2004, 10:53 AM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
I wouldn't put it inside your cab if you like your sanity. The noise will make you crazy. Here's mine...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-23-2004, 12:13 PM   #9
Izzy
Trucker.
Izzy's Avatar
It doesn't need to be to DOT standards but whatever specs the Scuba shop sets or since he's using his own comp and not compressed air it won't matter.
Izzy is offline   Reply With Quote
Old 02-23-2004, 01:09 PM   #10
Prerunner1982
i am obviously not into bags and such yet, why is this though? how big does the enclosure have to be to be considered open? primered thunder has his in his cab?
Old 02-23-2004, 01:19 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
The compressor generates a lot of heat. If it's not in an area where it can breath, it will draw in the hot air that it creates around it, and burn up...
Old 02-23-2004, 01:35 PM   #12
Prerunner1982
that is kinda what i figured, thats why i mentioned cooling fans in my idea... i guess not even that would be enough........
Old 02-23-2004, 03:04 PM   #13
PrimeredThunder
Back from the Dead
The Scuba tanks are great, I was able to get a couple of them cheap and I'm only running a 145psi pressure switch so I dont have much to worry about. besides, its fun to have a couple mounted in your bed and make the unaware street racer think its nitrous Since the compressor is in my cab, I wired a switch to the relay were i can turn it off when I'm in the truck and run it when I'm out...helps some but its still a hassle, wouldn't recommend it.
Salem, Oregon
