For those that are bagged...
I'm planning out to redo my suspension in my 75 GMC Sierra Classic, and am trying to calculate the drop. I don't intend to lay frame, but want it fairly low when deflated, but still at a driveable hight in the event of a failure. I learned a long time ago with my S10 with hydraulics that driving home with a quarter panel on the ground isn't fun.
So my question is, if I go with Firestone 2600 bags up front with the OEM spindle and lower control arms, what will the drop be? From what I can tell, it seems to only be 2" lower than stock with the bag deflated, but want to be sure. I'm thinking 5" drop in the front will be low enough to my liking and still be driveable. So if the bags provide a 2" drop, I was thinking I could go with a 2" spindle and 1" drop lower control arms. Or is there a better setup for the front? Thanks guys... Scott |
how are you figuring these measurements? even with a stock spindle and control are the bags are going to get you much lower than 2 inches from stock
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
Under construction!
2001 Silverado bagged on 22's. *Sold* |
#4 | |
Under construction!
No problem.
#6 | |
83 Monte Carlo 92 Camaro |
well i think i see what your doing now. you just want an adjustable suspension that will drop you down to something like a 5/7 drop max and then lift you back up to stock. in that case i would leave the stock spindles and control arms and only use bags, that should limit you from going too low. and you can always add spindles later if its not low enough initialy. i think you also might be able to use limiting straps of some kind to keep it from dropping too low when deflated
Under construction!
.....but there's no such thing as "too low".
#9 | |
I'm sure it doesn't matter, just like all my other projects I start out with a slight adjustment to the suspension and I am never satisified until I can push bottle caps with my front bumber. When It's all said and done, I'll probably end up laying totally out. ![]() |
#10 | |
Trucker.
#11 | |
Happy to be here
![]() Join Date: Mar 2000
#12 | |
Signals in the bumper.
Jeff C. 1981 Chevrolet Silverado - Under major construction...again. link 1962 Chevrolet Impala 4D Sedan moredoorclassics.com 1936 Ford Pickup - Frame-off in progress link 1979 Chevrolet Camper Special Flatbed link |
#13 | |
Happy to be here
#14 |
lol, mine was a little cheaper and I had the material laying around the house. But I like your idea a lot more.
#15 | |
Under construction!
A bag failing is not to worry about. Besides, how would you limit the suspension from going down? ![]()
#16 | |
Trucker.
#17 | |
driving is in my blood
And if all you want is a 5" drop, then do it static. I daily drive my truck with 5.5" up front drop a minimum of 70miles a day to and from work.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
