02-22-2004, 03:47 PM | #1 |
Fuel Pressure
What is the easist way to hook up fuel pressure guage dont need anything fancy or in the cab just for diagnostics reasons mostly?
Also what pressure should I be around?
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
02-22-2004, 04:12 PM | #2 |
www.73-87chevytrucks.com
For diagnostics, I would put it inline between the pump and the carb. As for pressure, it should be between 5-7 for carbed.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
02-22-2004, 05:18 PM | #3 |
What can I use to put it inline on rubber hose?
02-22-2004, 05:24 PM | #4 |
What type of pressure sensor are you using? The one I am talking about is an inline. You just connect a hose on each end.
02-22-2004, 05:29 PM | #5 |
I dont have any right looking to buy one hopping some one can point me to one?
02-22-2004, 09:05 PM | #6 |
Something like this with a T-connector with fuel barbs on the T to run the hose to.
http://www.jegs.com/cgi-bin/ncommerc...88&prmenbr=361
02-22-2004, 09:25 PM | #7 |
Yes like that only with barbs for fuel line.
