02-22-2004, 06:33 PM | #1 |
whats that smell?
SM465 to NV4500 conversion?
Hi Everybody,
I would lke to find out what all is involved in swaping a NV4500 into a '67-'72 3/4 ton 4x4? Thanks, Erik
'29 Chrysler model 65 all original, 2nd owner ***FOR SALE*** '63 Impala SS 283, 3-on-the tree, flowmaster 2 1/4" dual exhaust, performer intake, edelbrock 600 carb, chrome 15x8 rally's '65 Impala SS, built 332, 700R4, 3.73, 2 1/2" mandral bent duals w/H pipe, Flowmaster 40-series deltaflows, MSD Mallory, too many modifications to list '72 Chevy Suburban 4x4, NP205, TH350, balanced 357 (.040 350), 268 high energy cam, 9.2:1 comp, 1.94/1.50 heads (ENGINE BUILT BY THE GREAT RAYZOR or if you know him RAY, WHO POSTS ON THIS BOARD AND CHEVYTALK), 3/4 ton leaf springs, 4" lift, 35/12.5/16.5 Grabber MT's, Rancho shocks, Rancho dual steering stabalizer, American Eagle 143's 16.5x9.75 6 lug, 4.10's, 12 bolt rear limited slip, Dana 44 front limited slip. Carter 600, performer intake, headers and flowmaster exhaust system very soon. '74 GMC 1500 Super Custom, Factory 3/4 ton springs, built 400sb w/3947040 heads, 475 hp, 750 edelbrock, ceramic headers, TH350, B&M holeshot 2000, 2 1/2" duals w/ H-Pipe, 40-series delta-flow Flowmasters, Gibson tips, Fey Outlaw 8" drop bumper. '95 Impala SS Flowmaster cat-back, K&N, 255/50/17 G-Force T/A, Dark cherry metallic, 27,000 miles, extreamly fun vehicle '95 Chevy K2500, ex-cab, long bed, 350, AT, Flowmaster cat-back, 265/75/16 Mud Kings, 16x7.5 Centerline HT cast wheels, Leer high rise canope, bed liner w/ mat, loaded.**FOR SALE** |
02-22-2004, 07:58 PM | #2 |
Here's a link to some information on this swap using an NP 205 transfer case and the NV4500. Not sure what you have in mind for a transfer case.
http://67-72chevytrucks.com/vboard/s...threadid=35373
Larry 72 Chevy SWB 4x4 71 Chevy SWB 4x4 My Work Truck "Don't confuse enthusiasm with capability" |
02-23-2004, 12:14 AM | #3 |
whats that smell?
Hi ljbear,
Thanks for the reply. I don't have the truck yet, but if I end up with a 4-speed rig I plan on going 5-speed. Did the shifter line up with the original hole in the floor? So from what I have read it sounds like advanced adapters has almost everything I would need to do the job. The transfer case most likely would be the stock 205, so I will have to bore out the housing for the larger barrings of the 32 spline shaft. I already have evperiance with driveshaft modifications so thats not too bad. Around how much did it run you to do this? Thanks, Erik
02-23-2004, 12:54 AM | #4 |
Erik,
Advance has everything to do the swap, and for some of the parts they are the only choice. Starting at the front you can find a used bell housing that will save a bunch of money over the one Advance makes. If you can find a 205 that was behind a Turbo 400 you will probably save $500 less the cost of the transfer case. The new input for the 205 and having the case bored was about $500. I found a used transmission and had it completely gone through with all new bearing and I have about $1600 in that. The adapters and brackets are about $600. My swap cost a bit more as I was using the newer flywheel and the hydraulic clutch. Everything involved I think I have about $3000 in it. I'd have to open up my Excel document on the truck to get the actual total, but I don't really like doing that, especially when my wifes home.
02-23-2004, 03:08 AM | #5 |
whats that smell?
Hi Larry,
Thank you for the information, I really appreciate it! Thanks, Erik
02-23-2004, 11:22 AM | #6 | |
I've got an SM465, and I was contemplating this swap. After I drove it for a while, though, I realized that GM did a pretty good job with selecting the rear gears on this, and it actually does pretty nice on the highway. I've got 3.08s in the rear, and I figured it would take more miles than I ever plan to drive to pay back this switch. Just my two cents! Brian |
