Old 02-22-2004, 06:33 PM   #1
jugernot
Life, Be In It.....
jugernot's Avatar
HELP rear-end ID
I moved my truck, with not fluid in rear end. Can some help me ID it. It have 12 bolts on rear cover, but I am wondering if it is from a 67-72 truck or something else. I has been narrowed and modified externally. I am not sure whats inside, I took some pic of the differential gears.
jugernot is offline   Reply With Quote
Old 02-22-2004, 06:42 PM   #2
jugernot
Life, Be In It.....
jugernot's Avatar
Another Pic
Old 02-22-2004, 06:46 PM   #3
jugernot
Life, Be In It.....
jugernot's Avatar
another
Old 02-22-2004, 06:58 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Look's like a 12 bolt narrowed and set-up for a 4-link set up...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 02-22-2004, 07:25 PM   #5
jugernot
Life, Be In It.....
jugernot's Avatar
How do I figure out what gears are in the differential.
Old 02-22-2004, 07:36 PM   #6
71swb4x4
71swb4x4's Avatar
An easy way to get a rough idea is to turn a tire 360 degrees and count how many times the gear rotates. That will be your gearing. So 4:11's should turn a little over 4 times for every turn of the tire. Mark the tire and gear with chalk ot masking tape so you know eactly where they start.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 02-22-2004, 07:39 PM   #7
walker
walker's Avatar
Easiest way is too count the ring gear teeth and divide that number by the number of pinion gear teeth. It is easisest since the is no cover on it.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 02-22-2004, 07:47 PM   #8
lukecp
Formerly yellow72custom
lukecp's Avatar
The number of teeth are stamped on the ring gear. No need to count them. Just rotate the ring gear until you see the stampings, sometihg like 41 11 and divide the big number by the little and you will have the gear ratio.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
