Old 02-22-2004, 08:16 PM   #1
gldevall
gldevall's Avatar
What did you get done this weekend?
I'll start this early so I can post a pic. I got around to changing out my dented up fender.
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 02-22-2004, 08:24 PM   #2
gldevall
gldevall's Avatar
Word of warning for anyone replacing a fender. If you refer to the Haynes manual for this and they say you have to remove the hood, they are full of crap.
Old 02-22-2004, 08:39 PM   #3
AirMale
AirMale's Avatar
I received some new drag slicks from FEDEX I won on Ebay. I think I stole these things. Hows $102 for a NEW pair of Goodyear 27.5X12.0X15 D6 compound? These are stiff sidewall slicks that should work well on heavy trucks. I'm mounting them on 15X10 truck rallys that I recently purchased.
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 02-22-2004, 08:50 PM   #4
1974ChevyC10
Overworked and Underlaid
1974ChevyC10's Avatar
did some general clean up between my two trucks-my dad and uncle who are helping me with this like to make messes and it was getting to a point that we started to lose track of things so some policing of the situation was needed.installed the tilt column from 74 into my 78-its installed loose right now b/c it started to rain hard this afternoon and i didnt want to get drenched.so it will get tightened down after the wiring is hooked back up.pulled the bad tranny out of my 78 and took the pan with the drain plug off it and put it onto my tranny.nothing major but every little bit helps.
I'd rather push a Chevy than drive a Ford
The Beast-1978 C10 LWB
Red-1978 C10 LWB
(Uncle Mike)Michael Henry Millett 11/5/1957 to 03/08/2012
Gone but will never be forgotten-RIP
(Uncle Chuck)Charles Manning Gulbronsen Sr 1956-2012
Taken from us to soon but you will live on in our hearts-RIP
1974ChevyC10 is offline   Reply With Quote
Old 02-22-2004, 08:54 PM   #5
1FaastC10
1FaastC10's Avatar
went yesterday and picked up my 465/205/Hydro clutch setup from justinf, and today worked on my buddy's non-running '94 Firebird. i've got to make a 2 1/2 hour drive home here in a few minutes.
1FaastC10 is offline   Reply With Quote
Old 02-22-2004, 08:55 PM   #6
low 84
low 84's Avatar
i pulled my motor back out, had it out in about 4-5 hours.
(phone pics i took, i'm not in them, those are drunk friends )
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 02-22-2004, 10:01 PM   #7
swervin ervin
You get what you pay for
swervin ervin's Avatar
Nothing like a bunch of drunks working on vehicles.
Heck, I finally decided to wash mine. I very rarely drive it and it hasn't had a bath in a couple months.
Really been deglecting the old girl. Haven't really been motivated to do anything lately. I got some plans for things I want to do, but that's about all they are, is plans.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 02-22-2004, 10:11 PM   #8
Gregsmx
Gregsmx's Avatar
I replaced manual operated window cranks with power operated units, including the power locks in both doors today. This is great on a pre-76 Blazer as it was not an available option, but they fit nicely. I had purchased the used operators and wiring harness from a fellow member.
The only trouble I ran into today is the power actuator for the locks wouldn't push the lock opened or closed. I think there is a lever that is necessary between the actuator and locking mechanism, not sure.
Also, was only able to operate with direct current from the battery. Havn't figured out the wiring harness wiring connections to the fuse panel. I have a thread on this board and I'm sure someone can help me figure it out.
'75 Blazer RAT 4X4 "BLAZIN" - Custom frame off
Here's the website I'm uploading pics to: Greg's frame off project
Gregsmx is offline   Reply With Quote
Old 02-22-2004, 10:45 PM   #9
BaggedC10
Under construction!
BaggedC10's Avatar
Nothing.....as usual.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 02-22-2004, 10:54 PM   #10
Russell
Professional Grade
Russell's Avatar
I broke my alternator, does that count?
I'm gonna skip my options tommorow to fix it so I can still meet Riptide after school
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 02-22-2004, 10:56 PM   #11
Did a few things on the 82 yesterday..... carb & dash work..small but finally things work
http://67-72chevytrucks.com/vboard/s...threadid=91732
Blew pine pollen off all trucks today, but it'll be back again....Living in the south.!!!
Old 02-22-2004, 11:02 PM   #12
CRRoy71
I re-painted my rally wheels, and took the hard top off to put the soft top back on. I actually wore shorts today.
Chris
'92 ext. cab s/b 4.3L "Sparky"
'04 crew cab 2500 4x4 6.0L
CRRoy71 is offline   Reply With Quote
Old 02-22-2004, 11:30 PM   #13
Blue Beard
Blue Beard's Avatar
Worked on the shop wiring.......
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 02-22-2004, 11:44 PM   #14
phantom dually
Project92 SWB stepside
phantom dually's Avatar
I worked in the garage on my 454 project I purchased from Tracy Focht here on the board. I have it all torn apart and am currently smoothing the block clean of all casting marks. I plan to get it to the machine shop by tuesday. Buildup is going to be all forged. I need to get the block cleaned and checked. I am not sure on what I am going to bore it to or stroke it?? I am thinking a 468??
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 02-23-2004, 12:05 AM   #15
Slonaker
Insert Witty Text Here
Slonaker's Avatar
All I did was to wash mine and take a few pictures. Of course it rained on it this morning...
I think this is the first pic I have posted since I rebuilt the front end and added the Western Chassis 2½ inch drop spindles. I will install the 4 inch drop springs over "Spring" break.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 02-23-2004, 12:13 AM   #16
1974StepSide
Play it Loud...
1974StepSide's Avatar
I bought a vacuum gauge tester, and a tach/dwell meter. Played around a little with both of them to tune my carb. Then I realized I really had no idea what I was doing... So now I'm on the board to find some info on how I should use them.
Big Moe
1974 Cheyenne Super Stepside, 350/400, Hooker Headers, Flowmaster Mufflers... Needs new doors, fenders, hood, and paint.
1952 Chevy Pickup waiting to be brought back home!
1974StepSide is offline   Reply With Quote
Old 02-23-2004, 12:33 AM   #17
low 84
low 84's Avatar
they weren't doing any work, lol
'05 1500 Crew Cab
RIP
Old 02-23-2004, 12:40 AM   #18
bigblock73
yeller
bigblock73's Avatar
got my cab back and mounted.
bigblock73 is offline   Reply With Quote
Old 02-23-2004, 10:39 AM   #19
N2TRUX
Happy to be here
N2TRUX's Avatar
Got a few things done. I got in late and didn't see this thread so as usual I started one when I got home. Here it is-What did you get done this weekend. Second edition
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-23-2004, 11:04 AM   #20
Low87on20s
Live from Atlanta
Low87on20s's Avatar
I had a long discussion with my father-in-law about completing the body work on my 87 and shooting a good coat of black primer on it before the All Chevy/GMC Nats in Pigeon Forge. If I can get it completely smooth and at least all in primer it might get a little more interest if I decide to part ways with it while I am there.
Paul
Low87on20s is offline   Reply With Quote
Old 02-23-2004, 11:24 AM   #21
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
Mike!!! A couple months! you talk about me neglecting mine! hahahahaa
Well not on my truck this weekend but I rolled up to Tulsa and worked on my bish's truck. Got Greg's Gauges and cluster and dash back together and put his new head unit in for him. Got a pic of his "low" truck too hahahahahaaha
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 02-23-2004, 11:48 AM   #22
Grim Reaper
SEVEN HOURS TO REPLACE EXHAUST GASKET! notice that was not plural.
For a laugh we pulled up the hours on the shops estimat program. 2.75 hours to change this side. Yeah right on a new engine maybe,
454 is the 88 has blown manifold gaskets on both sides. My buddy is a pro mechanic and said he would lend me a hand at his shop.
First I knew I had a broken off bolt into the passenger side head. Well what I failed to notice was there was two broken off.
SO start taking it appart and all three of the flange bolts broke. I was prepared and had all new hardware. So a total of 5 broken bolts to get one manifold off.
Had to lift the engine about 6 inches to get the manifold off. The air tubes stick WAY down into the exhaust ports. So that had it's entertainment.
Drilling the two in the head went well once we took the inner fender out so we could get a strait shot on it.
The three on the manifold didn't. Ended up drilling and tapping the two that went all the way through. The one that didn't was a blind hole. We had both heard of this trick with the torch where you could burn the bolt out and not hurt the mainifold. We didn't think we had anything to loose. We were already down to drilling and tapping so as long as we didn't over size the holes seemed like worth the try if it got use done fast. So I said let try it.
Well it didn't work for us. What it did was is harden the cast iron. We fried drill bits and couldn't get it to tap. Finaly said screw it and over sized it and had to weld the stud in. Crossing fingers that it will hold.
It is much quieter and as long as the welded stud holds I'll run with it. If it lets go I have one idea and if it doesn't work then I'll replace them.
Looking for a set of headers now to see what out there. I'm going to have simular problems with the driverside. It not leaking nearly as bad yet so plenty of time to see whats out there. I wonder if somebody has a set that will bolt to the stock Y pipe? Rest of the exhaust is in good shape. My buddy says to check out the Doug Thorely tri Y shorties.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 02-23-2004, 02:07 PM   #23
bagged81
Signals in the bumper.
bagged81's Avatar
I started it and moved it out of the carport to get some sun.
Jeff C.
1981 Chevrolet Silverado - Under major construction...again. link
1962 Chevrolet Impala 4D Sedan moredoorclassics.com
1936 Ford Pickup - Frame-off in progress link
1979 Chevrolet Camper Special Flatbed link
bagged81 is offline   Reply With Quote
Old 02-23-2004, 05:13 PM   #24
Zilverado
Zilverado's Avatar
Changed oil and filter on the Pathfinder. Truck's still parked in the country One of these days....
Zilverado is offline   Reply With Quote
Old 02-23-2004, 06:27 PM   #25
bpmcgee
bpmcgee's Avatar
I dug into the Blazer again.
I don't know if you recall, but I put a new engine in the Blazer last fall, and couldn't get the TBI running lean enough to emissions.
I think maybe I just wasn't letting it warm up enough. Seems to be running a BIT rich, but not horrible. Have to get everything straightened out and test it.
I put on new Edelbrock valve covers
Farted around with the temp sender.
Have fun,
Brian
bpmcgee is offline   Reply With Quote
