Old 02-22-2004, 08:38 PM   #1
72c10step
WHYBYNU when old will do?
72c10step's Avatar
Attn Rage'nrat: Tach in dash ??s
I got a Sunpro tach to put in my dash cluster like you did with yours, and it looks like I have to cut the back metal piece to let teh tach fit in all the way. It also looks like it'll push the circuit board piece out some. Did this give you any problem, or did the tach slide right in? If it did give you a problem, how did you fix it? See circled area in picture below, thanks,
-Jay
-72 Chevy C10 Stepside
-2002 Chevy Silverado 2500HD 4x4
-1984 Jeep CJ7
-1995 Polaris XCR600 Custom
-2003 Honda 300ex
72c10step is offline   Reply With Quote
Old 02-22-2004, 08:42 PM   #2
lukecp
Formerly yellow72custom
lukecp's Avatar
I'm not Rage 'n Rat, but i did the same thing.
I had to cut the grey metal piece with a dremel, and there was enough slack in the printed circuit that it simply went over the back of the tach with no problems. It was a $40 Sunpro tach, too.
Good luck!
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 02-22-2004, 08:47 PM   #3
70c10
67-72 Addict!
70c10's Avatar
Lucas how did you cut the lense?. Dremel also?. Thanks
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 02-22-2004, 08:53 PM   #4
lukecp
lukecp's Avatar
Yup.....sliced everything with cutoff wheels on a dremel. Smells kinda bad with the burning plastic, lol. I would imagine a big hole saw might work a little better.
Pretty easy modification...and looks much better than the tach held onto the steering wheel with a hose clamp, lol.
Old 02-22-2004, 08:55 PM   #5
72c10step
72c10step's Avatar
Good luck!
Thanks, that's what I was hoping for!
-1984 Jeep CJ7
-2003 Honda 300ex
Old 02-22-2004, 09:08 PM   #6
rage'nrat638
rage'nrat638's Avatar
i just trimmed the rear of the tach.....and cut the len's with the cut off tool ....
but both ways will work....
i also installed a 3/8" wide vent ball felt around the cluster hole to hold it firm.....leave some wire inside the dash so you can pull the tach out......to change the buld if needed....
i just drilled a hole into the back metal for the wire's
rage'nrat638 is offline   Reply With Quote
Old 02-22-2004, 09:10 PM   #7
dinnut
dinnut's Avatar
i didnt cut the metal piece all the way in the back. i probably should though. the tach sticks out. ill get a picture tomorrow.
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 02-22-2004, 09:13 PM   #8
rage'nrat638
side view
Old 02-22-2004, 09:28 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Hmmm, I guess my conversion was kinda butch.
I massaged the back panel with a 5 pound hammer for rear clearance and chopped up the lens with a pair of dikes. (Or do we call them women in comefortable shoes now to be P.C.?)
Old 02-22-2004, 09:41 PM   #10
72c10step
72c10step's Avatar
LMAO!!!
-1984 Jeep CJ7
-2003 Honda 300ex
Old 02-22-2004, 09:47 PM   #11
rage'nrat638
OOP'S.....DOHOO
Old 02-22-2004, 09:57 PM   #12
72c10step
72c10step's Avatar
Where did you guys hook up each wire to (ground, red wire, green, white, etc.)?
-1984 Jeep CJ7
-2003 Honda 300ex
Old 02-22-2004, 10:01 PM   #13
dinnut
dinnut's Avatar
i hooked white wire up to a wire going to a light somewhere or you can plug it in the slow in the fuse box for lights... power, you could run off of another wire or run off of the ign unfused if you put an inline fuse. or if your radio power slot isnt being used there ya go. green goes to negative side of coil or tach side of hei distrib. ground i hooked up in wrong place so i need to find out where everybody else hooked it up.
70 longbed
496/th400/Ford 9"
