02-22-2004, 09:15 PM | #1 |
WTB Parts for 69-72 chevy
First I Need 5 lug front and rear 5 lug parts
->5 lug disk front with possilbe brake booster must work!!! ->5 lug rear Rear Coil Rear End 12Bolt must be 3.08 or 3.42!!! -> Fleetside Shortbed!! ->Small Block Steering pump and power steering box workin!!! ->Small Block pulley's and fan original fan in Execellant conditinon -> Tilt or Non Tilt automatic steering column with attachment two steering box -> Good Front Fenders |
02-22-2004, 10:57 PM | #2 |
5 lug
Here ya go, 5 lug front and rear,307 POSI, ps pump and gear box, front sway bar,auto cross member,motor mounts,even the cab if you want it, and the best part is that I'm close to you. $750.
02-22-2004, 10:58 PM | #3 |
02-23-2004, 02:29 AM | #4 |
I've got a fan and pulleys I can pull off and sanblast from a '69 CST/20, pulleys have surface rust fan doesn't. $40 shipped for fan, water pump pulley, harmonic balancer sound good?
