Hope someone can help me out,
I resently purchased a 77' Chevy K10 which the previous owner ripped out all the emission crap & registered it in AZ. My problem is, I live in California and I need to get it smogged. Currently I have a 400sb with a edelbrock 3701 manifold and edelbrock 1903 795cfm carb, and my question is "What else do I need to pass emissions?" The GVW is 6200 so I know I don't need cats but i'm lost after that. can anyone help me with a list of parts that I need. Any & all help appreciated. |
Hmm..on a K5, I'm not sure...but I know that the #3701 manifold will pass (same one I'm running). Just make sure you've got a factory air cleaner, with the THERMAC system, and a heat-choke-stove tube in place. You'll probably also need an AIR pump, but I'm not sure on that...refer here for a better description...
Smog Stuff ![]() |
Tim, he didnt mention anything about a K5. he has a K10 which is a 4x4 pickup. a K5 is a Blazer or a Jimmy.
#4 | |
Don't they allow for mods or swaps on motors....?
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
Move to a different state.
It needs everything it had stock. Start by looking to see if it still has it's emissions sticker on the core suport. At the very least it's going to need EGR, EVAP, PCV. Probably needs cats and might even need a Air pump. You basicly have to put it to stock or have C.A.R.B. # and they will check.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
![]() Join Date: Dec 2003
You WILL need the air pump and injector tubes, as well as heat riser butterfly-plate hanging off the pax side exhaust manifold, and the PCV stuff. You could probably get away without the heat riser going from the pax manifold to the air cleaner but safer with. If I get time I'll take a pic of whats left over from my stock setup on my CA registered 76 K10. I've just removed the Air Pump and associated BS.
Thanks everyone,
Not only did the previous owner remove the smog gear, he removed all the stickers too, got them on order though. I tried to price an EGR valve for it and the parts guy doesn't show one made for the 77' K10? I looked up parts for emissions on another site and they show the following: A.I.R. pipes & manifold (got headers with the ports in the mail), air check valve, air pump (got one off a 396cid el camino), vacuum valve, cannister filterair cleaner temp sensor, thermal air temp control valve,vacuum moter,vapor cannister and a EGR gasket (but no valve)? Does all this sound right? Wish I could move to a non-smog state, CA is killing me on emissions and the price of gas $2.19. |
Man, I would hate to try t pass emmisions. Sound like a headache, but good luck.
-90 454ss http://www.imagestation.com/album/?id=4289115843 -04 TRX450R -77 c-10 http://www.imagestation.com/album/?id=4290506213 SOLD -82 c-10 SOLD -02 CRF450 SOLD |
#10 | |
