Old 02-23-2004, 04:26 PM   #1
J.Lance
Too many is never enough!
'72 Blazer F/S- Detailed Description!!
Here is a link to my previous post with pictures:
http://67-72chevytrucks.com/vboard/s...threadid=91289
Asking price is $1300 but I would think a $1000 might get it bought.
I just got back from looking at it again so I can describe it better.
Chassis: Frame looks to be straight with no issues. D44 with discs up front and 12 bolt rear, I believe 3.73 ratio. Power steering and brakes.
Drive Train: D44 with discs up front and 12 bolt rear, I believe 3.73 ratio. TH350 Automatic with NP205 x-case both working well. 350c.i. blue motor with 2 barrel carb, needs some help but runs.
Body:
- Both front fenders and inner fenders have some rust. Hood is good.
- Inner and outer grill are solid driver quality.
- Passenger '72 door has a little rust in both corners but very fixable with no speaker holes. Drivers door is pre-'72 and in nice shape with no rust.
- Driver floor pan, kick panel, rocker, and quarter panel behind door have been repaired with patch panels. Seems to be a decent job but still needs smoothed and finished.
- Passenger floor needs a little work where the floor pan meets the kick panel, needs rocker and inner rocker, quarter panel patch.
- Both rocker boxes need some patching. The drivers side had been cut back some but no patch installed.
- Rear quarters are pretty straight for the exception of the areas already mentioned.
- Tailgate is straight on the outside but a few spot welds have come loose on the outer skin. Easy fix. Bowed on the inside.
- The double wall top is in good shape with no major defects.
- The rear hatch will need a T-handle and a little repair to a crack where the handle mounts, typical but not near as bad as some I've seen.
- Uncut dash.
- No rear seat
- The rear floor has rust around the wheel wells and rear corners.
- Aluminum wheels with 33" tires. A little tread left yet.
Well, that's about it for now! Give Marvin a call, 303-279-1720 with any questions or shoot me an email and I'll try to answer as best I can.
Jason
Jason
1968 K10 SWB Fleetside
1971 K2500 GMC LWB
1968 K20 (later frame, donor body)
1972 C20 LWB parts truck
1993 K2500 Suburban, tow rig, 454, 4L80E
NEW!! 18' Siem's car hauler
2004 Honda Odyssey (family man!)
J.Lance is offline   Reply With Quote
