Old 02-23-2004, 08:38 PM   #1
max91326
Engine Number
Hey guys,
I have a 66 GMC 3/4 ton, and i believe that the engine was replaced, I dont know when or with what exactly. It's a chevy, v8, but i dont know the size, and I got the block number, but dont really know what to do with it.
The number is:
V05I7YW
If someone could help me out, to find out what size and the specs of this engine is, or tell me where to look, I would greatly appreciate it.
Max
max91326 is offline   Reply With Quote
Old 02-24-2004, 03:56 PM   #2
NAPCO ken
NAPCO ken's Avatar
Look for the casting # on the block, it's on the rear of the block below the driver's side head. It should be a # like 3900010, or something along those lines. You can check the casting # yourself at www.mortec.com
ken
'58 Chev NAPCO 4x4 short
'60 GMC Suburban 4x4, restored
'60 GMC 3/4T stepside 4x4
'64 GMC Suburban 4x4, restored
'90 Chev Suburban 4x4, dually, ZZ502
'77 GMC Suburban 4x4, one ton axles, 12" lift, 39.5"s
'88 Chevy crewcab dually 4x4, 10" lift, 42"s (x6!)
'03 Jeep Wrangler Rubicon
'79 Chev 3/4 Suburban 4x4, 400-400-203
NAPCO ken is offline   Reply With Quote
Old 02-24-2004, 07:20 PM   #3
bpmcgee
bpmcgee's Avatar
V: Flint, MI
0517: May 17th
YW: This doesn't match any small block engine codes. Could it be YV? For Big Block, YW would be a '69 427.
Brian
bpmcgee is offline   Reply With Quote
Old 03-11-2004, 11:30 AM   #4
jwart
engine #
try: www.v8s-series.freesavers.com/sbc.htm this has alot of info & #s id's. also should have serial# on right/pass. side front of motor on deck forward of head. good luck. jw
jwart is offline   Reply With Quote
