Old 04-02-2002, 10:45 AM   #1
REPO1
Shortbox wanna-be.
REPO1's Avatar
Post Can the oil pan be removed on a 402?
Is there enough room to get the oil pan off the engine on a BB402?
Or does it need to be jacked up or anything?
I would like to fix the oil pan/rear seal leak and maybe check a couple of bearings while I'm in there.
Reid
Sylvan Lake, Alberta, Canada
1970 Chevy C20 Custom Camper
#s matching 402BB Turbo 400 trans.
Air conditioning, power steering, manual brakes.
73,600 Original Miles!!
(Add on 2000 more from raod trip!)
402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton)
'71 Camaro SS 402/T400 resto
'97 Z28 (11.41@127MPH)
REPO1 is offline   Reply With Quote
Old 04-02-2002, 12:33 PM   #2
Desert Rat
Desert Rat's Avatar
Post
Yes it can be done,just a messy sucky job,my opinion be easier/faster to pull motor and put on a stand if you have the time,space,tools.only takes a couple hours.
Desert Rat is offline   Reply With Quote
Old 04-02-2002, 12:34 PM   #3
Desert Rat
Desert Rat's Avatar
Post
but i hate lying on my back in the driveway for long periods of time,seems i do better work when i cant stand over it and spill stuff in it.
Old 04-02-2002, 01:49 PM   #4
REPO1
Shortbox wanna-be.
REPO1's Avatar
Post
Thanks for the info. I will probobly just try and do it in place. I am used to working on a '97 Camaro, so this will be a piece of cake. I just wasn't sure if there was enough room to slide it out of there.
Old 04-02-2002, 01:59 PM   #5
Orence1
Orence1's Avatar
Post
Micah,
Is that you responding? Great to see you back on the board.
Larry
Orence1 is offline   Reply With Quote
Old 04-02-2002, 02:44 PM   #6
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
Post
Had to do it on mine to reconnect the oil sump the previous moron didn't install correctly. I pulled the bolt out of the driver's side motor mount and used a 2x4 on end on top of the floor jack to lift the engine enough to get the pan past the flex plate. I used the power steering bracket (I think) on the front of the engine to push up on. The pan won't come out of there unless you lift the engine a little.
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
