Old 02-23-2004, 10:42 PM   #1
diggy
how do you remove the dash?
i have removed three bolts from either side but it appears that the dash is also connected along the back under the windshield weatherstripping. what do i have to do to remove the dash completly? i want that dash to go into another truck.
thanks
diggy is offline   Reply With Quote
Old 02-23-2004, 10:55 PM   #2
greasemonkey
greasemonkey's Avatar
It is spotwelded in. You will have to do some cutting to get it out.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 02-23-2004, 10:57 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You can slice it under the dash pad and weld it into the other truck. This is rather easy and you won't have to pull the front glass to drill out the million or so spot welds.
Old 02-23-2004, 11:47 PM   #4
Gee_Emm
Depending on how good a job they did at the factory you might have some real hard times getting the dash apart where it is spot welded above the bolts. It isnt easy to get in there with a drill. You might find it easier to cut away the bad dash to gain better access to that area.
Gee_Emm is offline   Reply With Quote
Old 02-24-2004, 03:02 AM   #5
Hooter
My other Love
Hooter's Avatar
like Andy said, cut along the slits where the dash pad goes and along the ends of the das area if it spot welded there too.
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 02-24-2004, 03:32 AM   #6
diggy
thanks guys, i'll try that. i assume that you just re-weld what you cut and that it is covered by the dash pad.
Old 02-24-2004, 08:07 AM   #7
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
Time to break out the saw......
chevy_fatman is offline   Reply With Quote
Old 02-24-2004, 11:14 AM   #8
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
what it looks like removed.
sneakysnake is offline   Reply With Quote
