brakes went out while driving
i recently converted my 70 k5 to discs up front.....tonite i was driving home and the pedal went all the way to the floor. used the e-brake to get home. when i got home i found the banjo bolt on the driver side had been hitting the control arm and it tore the banjo bolt right out. i'm gonna probably need a new caliper and banjo bolt, but can i grind enough off the control arm and banjo head to prevent this from happening again?? luckily not much traffic on the way home
Glad your alright.
what kinda conversion did you use? I'm sure members would want to look for similar sign of wear on their conversion. No brakes is scary. I had a beater beretta's brake line go out on the freeway. lucky it was standard. i just down shifted to slow down. lup |
i used the spindles (and out) of a 78 k10, everything was pretty easy except for the brake lines...matching the drum's hard lines to the discs flexible. got another question though... i plan on converting the rear to discs later, can i do without the proportioning valve, or should i use one of the adjustable ones. i would like to use the stock but any information is welcome
71 blazer 700r4 350 edelbrock cam, 1407 carb, holley intake, hei accel dist |
Merciless Butcher
Good thing it didn't happen on the freeway. I would imaging the pucker factor would be pretty high on that one.
Your Bought And Sold....I Got Your Soul! |
losing brakes at 55 mph is fun stuff, let me tell you...blew out a brake hose last year and of course I had to stop at an oncoming red light. i didn't have time to slow down so i blew the red light and cut across the highway, made it home alright cuz my truck is a 4 speed. then a week later, i was driving my beater Festiva and it blew a rear wheel cyl and I lost them, luckily I was used to it and it also was a standard shift, made it home ok. i hope that is all i have to deal with brakes going out.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
