Old 02-23-2004, 11:04 PM   #1
billsbowtie
billsbowtie's Avatar
lights help please
i put my bed back on today hook my light harness bac k up and all my lights work but the right rear turn single and that side brake light want work either the park light works does anyone no whats wrong thanks bill
billsbowtie is offline   Reply With Quote
Old 02-23-2004, 11:17 PM   #2
cdowns
cdowns's Avatar
first thing i'd check would be the bulb
Old 02-23-2004, 11:35 PM   #3
billsbowtie
i have used 3 drifferent bulbs the park light works but nothing else
i have 67/72 chevy truck parts f/s.
Old 02-24-2004, 12:32 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
look at the dark green wire in your harness going to teh tail lights...you probably pinched it someplace or pulled it out of the back of the light.
Old 02-24-2004, 03:03 AM   #5
Hooter
My other Love
Hooter's Avatar
is there a ground strap going from your bed to the frame, sometimes just bolting the bed to the frame wont ground it good enough
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 02-24-2004, 04:03 AM   #6
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
Yep, sounds like ground probably. BUT CHECK YOUR HARNESS UNDER YOUR TRUCK FROM THE FIRE WALL TO THE TAIL LAMPS. This happened to me earlier this week, took my bro to lowes and noticed my left tail light was out, including blinkers and brakes, but my park lights worked. The next few minutes I had no cab light or running lights, then next few minutes, blown fuse, no lights it wasn't until today that I found the stripped wire on that harness under my cab. Take a look youll be glad you did!!!! If one turn signal goes crazy fast or hazards go crazy fast or something wierd like that about 85% sure its that harness....
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 02-24-2004, 04:35 AM   #7
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
Sounds like a ground issue to me also. Try cranking on the 5/16 bolts behind the tail light lens. I had the same problem when I put my bed back on and it cured my problem. Good luck!
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 02-24-2004, 07:51 AM   #8
Sweet72
Sweet72's Avatar
Exactly my thoughts, light assy. not making good ground to bed.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 02-24-2004, 10:55 PM   #9
billsbowtie
found the problem cut wire everything works now thanks guys
Old 02-24-2004, 11:30 PM   #10
Longhorn Man
Cool.
Everyone is too quick to say check your grounds. 99% of the time, if one filiment lights up, then the ground is good enough to light the other one.
However, there is that 1% of the time that will drive you crazy.
