Old 02-24-2004, 02:45 PM   #1
sam's 72
serpetine belt systems got a question??
I want to run a serpetine belt on my new 383. I really can't afford to go with the March pulley kit. I was wanting to go get a set up from the bone yard. My question is, the belt systems that I am looking at take a new style alternator. You guys that are running these type belts on your truck, how are you setting this up? Are you wiring in the new alt, or using your old alt. I have done converted over to a one wire alt on my 72. I would like to see some picture if possible. I was hopeing to be able to do this and run my alt.
So please help me out here.
72 LWB chevy truck.
Pasadena, Texas
sam's 72 is offline   Reply With Quote
Old 02-24-2004, 03:02 PM   #2
jorgensensc
jorgensensc's Avatar
Not to hijack, but I'm interested too. Which type of water pump do you need, long, neck or short?
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 02-24-2004, 03:05 PM   #3
neonlarry
neonlarry's Avatar
What alternator are you running? Need more info than one wire, what model?
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 02-24-2004, 03:12 PM   #4
sam's 72
neonlarry
It is a powermaster that I bought from Scoggins, part number 67294
140 Amp GM Early Style Polished One-Wire Alternator.
Powermaster’s early style alternators offer not only the best in looks but also these performance advantages:
· True one-wire or three wire hookup
· Hi output at idle
· Proof of Performance tag
· 100 amp or 140 amp versions
It bolted right in to my old brackets when I did the conversion
72 LWB chevy truck.
Pasadena, Texas
Old 02-24-2004, 03:53 PM   #5
71swb4x4
71swb4x4's Avatar
I always thought that you could simply change the pulley on the alternator, but I am guessing by this thread that this isn't correct.
Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 02-24-2004, 04:10 PM   #6
neonlarry
neonlarry's Avatar
There are serp brackets for two different size alternators. The ones I have are for the CS-144 which are the larger of the two. The other (smaller) alternator is the CS-130 which I belive is the same bolt pattern as yours (so take your alt. with you). You also did not mention if you have A/C or power steering. You can put a serp belt pulley on your alt. and use it but you will need the water pump off of the serp vehicle and power steering pump (they all have them). Also there are ones with and without smog pumps the ones without look much cleaner on our trucks. I just took the whole works Alt., Pwr Steering pump, A/C compressor, Water pump and braces (be sure and take picturesof how they attach).
Also check out these posts
http://67-72chevytrucks.com/vboard/s...threadid=64369
http://67-72chevytrucks.com/vboard/s...threadid=61762
http://67-72chevytrucks.com/vboard/s...threadid=59092
Old 02-24-2004, 04:49 PM   #7
sam's 72
I do have AC and P/S. The AC compressor is the long one, was going to change to short one. So Larry what you are telling me is that I will need the ALT, P/S pump and A/C compressor for this modification? I really don't want to get one with the smog pump. My next question is how do you wire these new alt in?
72 LWB chevy truck.
Pasadena, Texas
Old 02-24-2004, 05:11 PM   #8
neonlarry
neonlarry's Avatar
What I am saying is that you can probably use your alt. you will just need to make sure you get the right serp bracket that will fit your alt.. There are serp brackets for two different size alts. Also it is much harder to find serp brackets that do not have a smog pump mount (just be aware of that). You can use the ones with the smog pump mount without the smog pump, I have even heard of someone grinding off the smog pump mounting tabs to get a cleaner look.
Old 02-25-2004, 04:26 AM   #9
Javy
Javy's Avatar
WATERPUMP
You must use a reverse flow water pump!
Javy is offline   Reply With Quote
