Embrace the Redneck
wanting to switch to a 350! what do i do?
I just got an offer today to buy a crate 350 still wrapped for $200.00. (very tempting
![]() What all do you have to do to switch from a 250 I6 to a 350 V8? thanks guys, sswj
'01 Camaro Son, you just can't get there from here... |
$200.00 What does he need Krack?
Good Score! Sell it and keep the IL-6! ![]()
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
Embrace the Redneck
it's my boss at TLE and he got a GOOOD price for 2 of them and he's passing on the savings to me and making a bit of cash for himself
Howzit?!?
"making a bit of cash" !! out of $200!!! Great Score... but I'm jealous! and would pay $400
Jason Hawaiian-J 70 Longbed, 307, Edelbrock Carb 1404, Edelbrock Intake 2101, Dual Roller Timing chain and gears, 214/214 cam, Comp Roller Rockers, dual Flowmasters. 1999 Chevy Tahoe 2004 Mini Cooper S 71 BMW 2002 - Sold |
Young Gun wth Fast Inline
Ill buy it for 300, it dont matter if you arent going to use it, unless you have another friend interested. buy it and save it for later.
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!! |
check out this thread
http://67-72chevytrucks.com/vboard/s...threadid=88711
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
My other Love
that thread covers everything, Im gonna save it!
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
Keep in mind that after you change out your engine, you'll wish you had changed your tranny, too. Once you start, it never ends and your wallet will always be empty.
scott
Silence is golden, duct tape is silver. - Scott |
Embrace the Redneck
i'm needing a bit more info about the swap. Like how do you get the clutch linkage to match back up, the engine towers, throttle linkage etc. any and ALL advice is not a bad thing.
Embrace the Redneck
ttt
You need the clutch linkage from a V8 factory truck, right from the pedal to the z bar. You will need V8 engine towers if you want to put the 350 in the forward mounting holes which is where the V8's were from the factory with the exception of the 4x4's. If you want to drop in the inline position, you can use the same towers. If you put it in the "factory" position, you will also need the front drive shadt from a V8 truck, as well as the tranny crossmember from an automatic truck. The crossmember will have to be moved forward to accomidate the engine moving forward. The throttle linkage will also need to be changed out from a V8 truck. It would be very handy if you have a spare V8 factory set up kickin around
![]() Oh also, you will need an oil PSI line from a V8, the inline 6 one is to long
Embrace the Redneck
thanks, thats what i need to hear
#13 |
If he keeps the 3 speed he won't need the crossmember will he? My 350 is in the I6 positiion. That makes the distributor very tight against the firewall. Since the engine mounts on the block and on the bellhousing, I don't think the crossmember is required, the 3 speeds are pretty light. If you use the I6 position and 3 speed tranny, a shortbed has the one piece driveshaft, right Dubie? If you need the hard to find V8 Z bar, I have one. I kinda wish I had put my engine in the correct position, but all I did was replace the engine a previous owner had installed. Then I got fed up with winding out the gears and pulled the 3 speed and installed a 5 speed. With the 3.73 rear end, it's a much better cruiser now. 2200 rpm at 70 now.
Is you $200 crate engine just a short block or do you get heads, intake etc.? Be ready for a lot of work and to spend some money for intake, carb, HEI, headers, clutch, water pump, pulleys, hoses, plugs, wires, heads (if not included), valve covers, air cleaner, fan, alternator, brackets.... it's a long list. good luck, scott
#14 | |
Is that clutch linkage you have from a V8 truck Scott? or is it the inline 6 setup?
#15 |
Embrace the Redneck
i get the head nothing else
#16 |
more
I forgot oil pan, dip stick, starter, flywheel, thermostat. If you can buy a cheap complete donor engine for all of the parts you need, that may be the way to go.
pm to ya Tim scott
