Old 02-24-2004, 06:39 PM   #1
westcasey
Angry Gas Tank Leak
Got a leak oon the right tank for my '85. Its right under the strap that holds the tank in place. Looks like a rock got up between there and rubbed through. Is there any way to do a patch or am I better off to just buy a new one. If so, better off with plastic or metal for the new one??
1987 GMC 1500 5.7L
1985 Chevy 3/4 4X4
2001 Chevy 2500 HD 4X4
2007 Chevy 3500 Duramax 4X4
westcasey is offline   Reply With Quote
Old 02-24-2004, 09:51 PM   #2
rage'nrat638
rage'nrat638's Avatar
empty tank.......sand heavily use brake cleaner......
install J.B. WELD
rage'nrat638 is offline   Reply With Quote
Old 02-25-2004, 12:07 AM   #3
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
Eastwood company sells a tank sealer which would work also. Seals the entire tank, will never get rust again.
NeCrOmAnCeR is offline   Reply With Quote
Old 02-25-2004, 01:28 AM   #4
78chevstepside
78chevstepside's Avatar
I worked with a guy who used to fix gas tanks on motorcycles. He would fill the tank full of gas and weld up the hole. a full tank would be safer to weld then a empty one. I still thought he was nuts. but he lived to tell me about it. I would drop the tank. fill it full of water and weld up the hole. Drain the tank. Get some soapy water. hook up a air hose inside the fuel tank with air blowing inside(with a good seal) Apply soapy water around the repair. If there is a leak it will bubble. Adding the tank sealer may be a good idea after you repair the leak
78chevstepside is offline   Reply With Quote
