05-31-2001, 09:47 AM | #1 |
new guy
hey...I have a 51 chevy PU...when it sits level in the sun the gas drips out from around the gas cap...the only solution I have found so far is to park that side on curb so it is higher than the other side. Is there a real fix to this?
Always remember you're unique. Just like everyone else. ------------------------ '51 Chevy 3/4 ton pick up Driven Daily |
06-01-2001, 10:09 PM | #2 |
a new filler to tank coupler .,.... new gas tank gasket (the one that goes up to the body from cap) or dont fill it up so high
and welcome aboard! ------------------ www.xframeimpala.com 68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor 56 big window short stepside 235 dual 1 brls 64ImpalaSS 327 70 C10 LWB fleetside custom/10 350/TH350 |
06-01-2001, 11:30 PM | #3 | |
08-19-2004, 11:53 AM | #4 |
so I tried a new cap, and that seemed to work for awhile..you can see the gas in the pic..then it will drip out from the cap..
08-21-2004, 01:15 AM | #5 |
Welcome.
I thought that when the pump shut off you were not too pull the triger again, as that ment it was full. Looks to me like it is real FULL, and even a new vented gas cap would NOT help !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
08-21-2004, 06:00 PM | #6 |
Cantankerous Geezer
$38 + ride for a sending unit and you will know how much gas is in the tank.
Fred There is no such thing as too much cam...just not enough engine. |
08-22-2004, 12:35 PM | #7 |
it looks real full, because the sun is shining and that's when it seems to rise..when the sun goes down and the tank cools off, the gas goes back down..
and ya, I do need to get anew sending unit..
08-23-2004, 01:00 AM | #8 |
Cantankerous Geezer
[QUOTE=Pawnbroker]it looks real full, because the sun is shining and that's when it seems to rise..when the sun goes down and the tank cools off, the gas goes back down..
QUOTE] That's what happens when gasoline is heated, it expands. One thing that will help is to fill it before you go somewhere, instead of after. That way you burn off some and leave some room for expansion. Something else you can do is keep track of how far you drive before fillup. Stock, these trucks get about 12 mpg. Fuel tank holds about 16 gal, iirc. That means you can drive about 200 miles on a tank, play it safe and figure 150 miles between fillups. I had a van that I drove without a gauge for 3 or 4 years, I didn't want to drop the tank to swap the sending unit.
08-23-2004, 11:04 AM | #9 |
Catchy title goes here..
ok then pawnbroker... I thought the board flipped out and was doin odd stuff when I saw this thread lol.. Welcome to the board ( a few yrs to late )
08-23-2004, 11:49 AM | #10 |
haha..this was the problem that brought me to this board a few years ago and it was my first post..I was suprised to see the thread was still here..and so is the problem. does anyone else's rig do this?
