Old 02-24-2004, 09:14 PM   #1
jlget
Door Lock
I'm repairing my truck at my computer tonight.
The passenger door will not lock with the door closed, however it locks with the door open. When closed the button will only push down about 1/3 of the way and then hits something.
I could remove the door panel and look, but it's warmer in the house.
Thanks for any advice (besides get my butt out to the garage) you can provide.
Jim
'72 Super Cheyenne
'78 Bonanza A36
'00 Cadillac DHS
'04 Chevy Avalanche
jlget is offline   Reply With Quote
Old 02-24-2004, 09:41 PM   #2
rage'nrat638
rage'nrat638's Avatar
sounds like a strike plate problem to me,,, did you try pushing on the door and locking????
try adjusting the plate around......
rage'nrat638 is offline   Reply With Quote
Old 02-24-2004, 09:48 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I agree, try pulling on the door or pushing on it. If the door then locks, you need to adjust the striker in that direction.
Does it have new - newish door seals on it by chance?
Old 02-24-2004, 09:53 PM   #4
jlget
Door Lock
The door has fairly new seals and tends to not shut correctly without a little extra force.
Jim
Went out and tried the push on the door while liking, and ya'll are correct again. It locked while maintaining pressure on the door.
Do I adjust the strike plate out slightly to correct?
Jim
'72 Super Cheyenne
'78 Bonanza A36
'00 Cadillac DHS
'04 Chevy Avalanche
Old 02-24-2004, 10:01 PM   #5
rage'nrat638
that will do it for sure ,,,my friend.....do it a little at atime.....
as not to get it to loose
Old 02-24-2004, 11:26 PM   #6
Blue Beard
Blue Beard's Avatar
Have the same issue on a 72 GMC..
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 02-24-2004, 11:28 PM   #7
Longhorn Man
Since the passenger door isn't used as much, I'd go ahead and adjust the striker a little bit.
For the drivers side I would live with it untill the rubber is 'broken in'.
Old 02-25-2004, 03:11 AM   #8
1969 GMC
1969 GMC's Avatar
be glad you don't have to take the lock mechanism out of the door and work on it, that is one big pain in the rumpus. the big rivet holding mine together decided to just give out last fall, at first I couldn't lock my door and then the door wouldn't stay closed when shut. Took about 2 hours, because I kept dropping small pieces into the door and then had to fish them out with a magnetic wand.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 02-25-2004, 07:59 AM   #9
chevymaz
What are you looking at?
chevymaz's Avatar
Dang this board is so informative. I am having the same issue with my truck. I figured it was the new door seals but I didn't know I could adjust the striker plate.
Greg
1971 GMC LWB
2005 Honda Element
2007 Honda Fit
chevymaz is offline   Reply With Quote
Old 02-25-2004, 08:40 AM   #10
MOTHERTRUCKERS
Curious are they LMC or Truck Shop door seals?
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 02-25-2004, 09:03 AM   #11
chevymaz
chevymaz's Avatar
I got mine from Manes
1971 GMC LWB
2005 Honda Element
2007 Honda Fit
Old 02-25-2004, 09:10 AM   #12
tom hand
CCRider
tom hand's Avatar
I would try to live with it for a while....if the new rubber is the problem, usually one good hot summer will solve the problem. If you adjust the striker more than likely the door will stick out
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 02-25-2004, 10:35 AM   #13
jlget
Door Lock
Many good comments. I tried to adjust and couldn't get enough relief to allow the lock to work without the door being out of alignment with the body panels.
I guess I'll see what the hot Texas summer does for it.
Jim
'72 Super Cheyenne
'78 Bonanza A36
'00 Cadillac DHS
'04 Chevy Avalanche
Old 02-25-2004, 05:18 PM   #14
roadking
same problem with mine, new door seals, ive moved the plate around with not a lot of luck. has anyone figured any easy fix?
71 C10 SWB
BLACK AND WHITE
350 CRATE TH350
ENJOY LIFE
roadking is offline   Reply With Quote
Old 02-25-2004, 06:07 PM   #15
superfly68
superfly68's Avatar
i have the same problem. been running for about 8 months without a seal because i was under the impression that i had to pay someone to align the door for me. I gave up after 2 days of trying to do it myself. I KNOW I KNOW...get's loud in there on the freeway but it's not at the top of my list.
no longer have a ride, but still a fan!
superfly68 is offline   Reply With Quote
Old 02-25-2004, 07:27 PM   #16
john
member #16
john's Avatar
A new door latch will cure the problem. New door seals make a worn latch worse because they put more pressure on the catch in the latch, which you relieve by pushing in on the door. The design of the latch does not allow for too much wear for the lock pawl not to function right. John
john is offline   Reply With Quote
