Old 02-25-2004, 02:02 AM   #1
danadena1960
Heater - A/C switch question
Hey All,
I have a 1977 K-20 with A/C. When I bought the truck the blower motor did not work on the HI setting or with the A/C setting on MAX. I replaced a resistor and relay on the heater box. Now everything seems to work fine, but I have noticed when I hit a bump it quits then comes back on. This happens only in the HI setting, all other setting do not seem to be bothered. I was telling this to a buddy and he said being I have the dash all apart I should change the actual switch on the insurment panel. He said those switches are common to go out and LMC sells them for $10. Has anybody else heard of this problem?
Thanks,
Dana
Dana
77 K-20 454
73 SS El Camino 454
68 SS Camaro 327
48 Chevy 216
755 John Deere
danadena1960 is offline   Reply With Quote
Old 02-25-2004, 02:36 AM   #2
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
Be sure to check the relay. High speed bypasses the resistor block entirely. Look at the evaporator box in the engine compartment near the resistor block. You will find a metal relay. Be sure to check the connections to it and the inline fuse for it also. (all located near the evap). If the blower cuts out in the max A/C position also, this is the cause.
NeCrOmAnCeR is offline   Reply With Quote
Old 02-25-2004, 03:07 AM   #3
danadena1960
Hello,
I did replace the relay, that is what in my opion got it fired up again. My El Camino use to eat them up all the time, why, I have no idea. Now it is a heater delete car. I did not know about the fuse though, I will look into that. How about the switch, have you ever heard of them going bad?
Thank you very much for the info.,
Dana
Dana
77 K-20 454
73 SS El Camino 454
68 SS Camaro 327
48 Chevy 216
755 John Deere
Old 02-25-2004, 11:50 AM   #4
NeCrOmAnCeR
Yes, they do go bad. Just wanted to make sure that the easy things were checked first. If you wiggle the switch I'd expect the blower to work intermitantly since you stated that the blower will act up when hitting bumps. The inline fuse is between the relay and terminal block where the relay draws power. Mine is a 74 GMC, I think the 77's were similar. The spring in the fuse holder on mine had gotten hot and collapsed, which caused intermitant contact with the fuse. Good luck.
Old 02-25-2004, 12:06 PM   #5
danadena1960
Thank you very much, I will check it out.
Thanks again for the infor.
Dana
Dana
77 K-20 454
73 SS El Camino 454
68 SS Camaro 327
48 Chevy 216
755 John Deere
