Old 02-25-2004, 04:58 AM   #1
687980chevy
687980chevy's Avatar
Ramhorns on a 4X4 which ones?
My 68 K-10 has a 350,sm465-4spd,Rockwell T-221 tcase. I want to put a new exhaust on manifolds back.I might go duals,maybe a single-anyway my manifolds go straight down I think I read that is the stock for a 4x4.I need to know because my truck was originally a 292 6cyl. Thanks
68 K-10,79 K-10,80 C-30
57 chevy convertible
79 Z28
687980chevy is offline   Reply With Quote
Old 02-25-2004, 06:55 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
yep. straight down both sides.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 02-25-2004, 08:41 AM   #3
Dean
Dean's Avatar
I agree. Straight down. Very easy to find them. Much easier than the 2WD manifolds at least around here.
Dean is offline   Reply With Quote
Old 02-25-2004, 11:58 AM   #4
dubie
dubie's Avatar
I have a set of both the staright down dumps as well as the 2wd angle back ones. I am gonna sell the straight down dump ones. They have been sandblasted and coated in 1200 degree flat black paint
Here is a pic of them
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 02-25-2004, 03:58 PM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
How much for them dubie? I want to loose the headers on the 71.
Old 02-25-2004, 04:41 PM   #6
dubie
dubie's Avatar
The studs need to be removed and replaced and the porting surface on one of the manifolds is a bit weathered, but still very usable. I see LMC now sells them, but for $150 per side. I can take some up close pics of them if you like, but it wouldn't be until the weekend. Or if your headers are in usable shape, maybe we can work a trade. Something like we pay each each others shipping cost or ??? Let me know bud
Old 02-26-2004, 03:51 AM   #7
687980chevy
I have a set straight down dumps,just didn't know if thats what I needed(for off the shelf ex.pipes to work)Did they have a heat riser on either side?
Thanks guys
79 Z28
Old 02-26-2004, 06:39 AM   #8
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Mine does not have the heat riser. The heat riser only came on the angled back type usually on the right side, you'd know it because I believe it will not accomadate a donut gasket.
Old 02-26-2004, 08:38 AM   #9
Dean
Dean's Avatar
There is a heat riser on the straight down dump manifolds that I use. You can however use the straight down manifolds on either side if you don't want the heat riser.
I can take pics of my latest K20 project if needed since I don't have exhaust on it yet.
Old 02-27-2004, 04:59 AM   #10
687980chevy
Thanks guys
Mine have a taper for donut gaskets on both manifolds.
79 Z28
