02-25-2004, 10:17 PM | #1 |
Have some questions???????
I have a 1969 that I am starting to redo so here are the questions I have I am changing from 6 lug to five lug.
1. I am going to lower it 2.5 or 3.5 front and 3 or 4 in the back would you guys go with Early Classic or CPP? 2. Which bolt pattern Early classic says 5 on 5 and CPP says 5 on 4 3/4. Which would you guys go with? 3. I want to convert power brakes and steering which kit would you guys go with? Any advice would greatly be appreciated
Larry 1986 3/4 Chevy Truck 454 2005 Z71 Tahoe 2002 Pontiac Trans Am WS6 |
02-26-2004, 12:11 PM | #2 |
Watch out for your cornhole !
I use only Early Classic stuff.
The bolt pattern, definitely go with the 5 on 5. That's a truck pattern and you'll be able to get a five lug rear end to match it as well as running normal Chevy pickup wheels. The little 4 3/4 pattern is for car wheels.
02-26-2004, 12:28 PM | #3 |
5x 4 3/4 is a truck pattern also.. it is the pattern for the toyota trucks 2wd. That is the pattern that I went to on my mazda to have a better selection of wheels for it.. but I would go with the 5 on 5 for the chevy, he is correct that is the normal pattern and have good wheel selection for the 69.. That is what I am going to..
02-27-2004, 05:51 PM | #4 |
I agree with Tx Firefighter on using Early Classic suspension components. Maybe a little pricey. But you get what you pay for.
72 Chevy LWB leaf spring rear,SBC 385 Fast Burn,Art Carr built 700r4,3.73 Eaton posi,one piece windows,lowered 4/5.5, 60/40 seat, shaved turn signals,shaved reverse lights,shaved stake pockets, stainless steel 21gall in rear, c-notched, vintage air,ps,pb,currently doing body work. 68 Camaro conv.327,turbo 350,pb,disc brakes,built it for the wife 38 Chevy Coupe on the back burner LIFE IS GOOD! SMILE |
