fatman front end
Ive been lookin at the fatman MustangII kit for my truck. Anyone here use it ? how difficult is it to remov emy front steering & suspension & replace with the fatman kit ?
Im thinking about using the coilover set up. do you use the existing steering column & powersteering pump? If you have this kit are you happy with it ? John
75 GMC C-15 short/step factory 454, lowered |
John, I got the Stage III kit (polished/tubular A-arms and coilovers). My truck is not on the road and won't be for a while. The Stage III requires welding some gussets on the back side of the crossmember for the a-arms but I don't think with the Stage I or II that is necessary. As far as the power steering I'm using the stock LS1 power steering pump and will be running a hydraboost set up also. You can get a fitting from Detriot Speed and Engineering , part #091401 for $18.00 to reduce flow while maintaining correct pressure on Mustang II racks when using GM pumps. Check on the review board as there is another member here (67dragtruck I think) that pushed this set up pretty hard and liked it. Also if you do decide to get one give Ed @ Mothertruckers a call (941 755 1272) as he is a authorized dealer and may be able to save you some $$
Edited for: See if they will sell one minus brakes. I got BAER brakes for mine so I have the new rotors, calipers, pads etc. that came with the kit.
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc Last edited by 68LSS1; 02-26-2004 at 05:52 AM. |
