user # 2756
![]() Join Date: Jun 2001
Stepside wood floors
I'm trying to clear the smoke and get a mental picture of how the stepside bedsides attach to a wood floor. I have a long step wood bed but the wood is completely gone and the cross sills are just hanging from the bedsides.
As I understand it: There's a piece of angle welded/bolted along the inside of the bedside, this sits on the wood and bolts go through the angle/wood and cross sills. Same for the front of the bed. Is this correct? Is there anyhting special about the angle? Where is it welded at? I can't tell on my bed (haven't really look close either).
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
Your correct! It's spotwelded to the bedsides 13/16' above the front and rear ledge the wood sits on and has a stamped lip like the strips and square holes for the carriage bolts.
Rest in Peace Ed. Thanks for all the good times. |
user # 2756
Is the front/rear ledge part of the bedside or the cross sill? Thanks,
The rear cross sill bolts to the bedsides and the wood rests in a notch in it. At the front the wood rests on the front panel lip and the first cross sill is only a few inches behind that. Hope this helps. I'm not quite sure I understand what you are wanting to know.
