i love summertime
TIM a.k.a Dubie<---------
here is a pic of the sway bar, i had to cut one of the clamps cause the nuts were rusted right on, but i think you need to get new clamps anyways because these arent the right sized ones to fit around you rear end, also the bushing piece that holds the bar to the frame was allready cut by some bozo at the yard, im guessing you will replace those as well since the rubber is pretty much shot anyway, the bar itself is in great shape and so are the 2 mounts that you bolt to the frame rails. here is a pic of the bar, pm me when you get a chance and we can exhange mailing adresses
thanks, Derek
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
i love summertime
oh i forgot to mention also you see in the pic the 2 mounting brackets have old bushings in them too, this is because i took them off another camaro rear sway bar setup, the ones that came with your swaybar were seized right on (those mf's were tight)
PM sent bud
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
