Old 02-26-2004, 09:27 PM   #1
72-396
Question 700r4 swap (help)
I have decided to swap out my th350 with a 700r. I have a 72 3/4 ton 4x4 th350 396. I have done a lot of research and what I have found is no one makes an adapter for my 205 to make it bolt up to a 700r4 I would need to use my current adapter. I have been told that I need to move my 205 back 1 7/8 ". Has anybody done this? I could really use some advice. Are there any other options besides moving the 205 t-case back.
Thanks Steve
1972 K20 custom camper 4x4 LWB 396 700r4
1965 chevy II 420 hp s/b 4 speed
72-396 is offline   Reply With Quote
Old 02-26-2004, 09:48 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
It is a common swap. Try Advanced Adapters.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 02-26-2004, 11:44 PM   #3
72-396
I spoke with advanced adapter and they do not make one.
Old 02-27-2004, 10:54 AM   #4
breeh
Recovering 67-72 Addict
breeh's Avatar
You need to exchange the mainshaft in the TH700 with the one that Advace Adapters offers for this. You then use your TH350/Np205 adapter. You will need to slide the trans back or the engine forward. I chose to move the engine forward to give me more room for my HEI. Try doing a search. This topic has been covered a bunch.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 02-27-2004, 11:16 AM   #5
72-396
Thanks for your reply. I have been doing searches and have not found any on this aplication which seems odd. Most people say this is real common but I have yet to find a article with this swap.
I have search google yayoo and typed in all sorts of titles.
thanks again
Old 02-27-2004, 01:54 PM   #6
bouncytruck
SKINNY TIRES RULE!
Ask the question on the message boards at ColoradoK5.com. I know there are several guys on that board that have made the swap. CK5 has an article on swapping out a TH350 for an SM465 but I don't see on on the TH350/700r4 swap.
bouncytruck 1972 K5
Old 02-27-2004, 05:28 PM   #7
Mark540
Advances Adapters makes an output shaft that replaces the current one in the 700R4, the tailshaft is removed and the trans has to be completely disassembled to install it, then it mates up directly to the 350/205 adapter. the 700 is 1 7/8 longer than the 350 so the motor can be moved forward(preferred) or transfer moved back, which means changing lengths of the front and rear drive shafts.
1970 GMC Burb 4x4 - 68 Chevy Front, FI LT1, 4L60E
1970 Chevy Impala 47,000 miles
2001 BMW 540i 6-speed
2002 Dodge Ram 1500 4x4 w/20's
Mark540 is offline   Reply With Quote
Old 02-28-2004, 12:23 AM   #8
72-396
Smile swap
thanks for your help!
