Old 02-26-2004, 09:47 PM   #1
Southpa
Southpa's Avatar
Rear axle interchangeability?
OK, its been 4 years since I swapped complete front ends from 1970 drum to 1971 discs. As many of you know thats also a swap from 6 lug to 5 lug. So whats the deal on getting 5 lug in the rear? Can I use axles from a '71, '72 or later or will I have to get an entire rear end from a later year truck? Current gear ratio is 3.07, coil spring susp.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 02-26-2004, 09:53 PM   #2
Slams_58
as far as I know Al, the axles were shorter in 67 only. 60-72 should work just fine
Slams_58 is offline   Reply With Quote
Old 02-26-2004, 09:59 PM   #3
JimKshortstep4x4
Talking
1970 trucks could have the longer axles like the 71-2's or the axles could be the shorter ones like the 67-69's. If you have the longer axles, it is a straight forward swap, (axle for axle). Otherwise change the rearend, redrill your axles or use spacers on the longer axles.
I believe the longer axle rear end is 57 3/4" between the backing plates. The shorter one is 56 1/2". I would suggest measuring so you know what your options are.
Jim
Old 02-26-2004, 10:33 PM   #4
Blue Beard
Blue Beard's Avatar
Saw a post awhile back that said there are two different axle widths...........
Can someone verify........
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 02-26-2004, 11:21 PM   #5
adamls
Gotta Startem Early
adamls's Avatar
If you want to pay for them, Early Classic offers a set of axles with 5lug pattern.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished
adamls is offline   Reply With Quote
Old 02-26-2004, 11:51 PM   #6
Blue_71
Bloo
Blue_71's Avatar
if you want them and want me to check the width, i have a set of 5 lug axles in a 70 12 bolt rear case
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 02-27-2004, 12:53 AM   #7
Southpa
Southpa's Avatar
No, I don't really want to pay for them brand new, . But I'll opt for getting them "previously enjoyed" from the boneyard. I know a place where I can dig some up, I just have to make sure I'm getting the right ones. So I'll take some measurements and assume that the donor truck with the same dimensions will be the one I need.
Original 350/TH350
Old 02-27-2004, 01:32 AM   #8
Chevy Wrench
former desert rat
Chevy Wrench's Avatar
Location: salt lake city, utah Home of the 3 M's Mormons, methlabs and minivans
I have read on the board that some people are using a spacer between the axle and the flange to make up the distance. I have never seen it done, but I wouldnt think it were impossible.
94 Chevy Silverado Ext cab 4/6 drop w/ 18's and 2500watt system (work truck). 67 Chevy swb under const. frame off custom, 20's, bagged and a large rat under the hood,and a 1940 Chevy truck under const.
Chevy Wrench is offline   Reply With Quote
Old 02-27-2004, 02:26 AM   #9
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
JimKshortstep4x4 hit it on the head, 67-69 is one length, 71-2 is another length and a '70 could have been either. Hope this helps.........Jerry
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Old 02-27-2004, 11:12 AM   #10
1-PU70
1-PU70's Avatar
My 70 had the longer ones and I got some out of a 77 PU with a 12 bolt.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
