Does anybody have any tutorials or pics of how to mount a front sway bar on a 67 -72 chevy frame????
Gotta Startem Early
Any sway bar from a 67 through the early 90's (I think) will work. The bar mounts to bothe frame rails and to the lower A-arms on both sides. If you have acces to a junkyard you can look a the setup and get a sway bar pretty cheap. Any vendor here can provide the brakcets.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished |
i have the sway bar already im just trying to figure out where exactly to mount it hey thanx for the help
Gotta Startem Early
Sorry, there are two holes on the lower a-arm about 3-4 inces from the shaft. The bar will go on top of the arm between the bolts. If you put the bar in place you will see where the holes are in the frame. One hole will problably have a rivet in it if your truck did not originally come with a sway bar. Drill it out and replace with a bolt.
cool thanx bud
