Old 02-27-2004, 04:10 AM   #1
XXROB
Question Installing tb400
I've put a tb400 in my 69-c10.It once had 3on tree.I went to an Auto..I want to have the shifter on the floor.The colum shifter swap seemed to complex for my lack know how? I would like to have any info. on installing afloor shifter or any recomendations on any brands that would work with this install? Someone told me that I may need a Man.Trans. hump from a 3/4 or 1 ton truck? Any help in this PROBLEM would be most helpful! Thanks
XXROB is offline   Reply With Quote
Old 02-27-2004, 04:52 AM   #2
1972C10
1972C10's Avatar
You wont need a man trans hump ..
Depending on what you want a cheap daytona shifter might do fine.
I wouldnt reccoment a B&M Z gate for a little more you can get alot better shifter auto zone sells the hurst promatic wich is a good shifter the b&m megashifter and light truck megashifter are also some good considerations
I run a Plain Megashifter in my truck Works good it can be dropped to drive but has to be racheted to manual low If thats something that you want immediate acess to might look into the unimatic althou its not a great looker IMO.
1972C10 is offline   Reply With Quote
