02-27-2004, 11:55 AM | #1 |
Gas tanks!!
Need help locating a rear (under bed) gas tank for my 72 3/4 ton. I want something HUGE!... Im tired of making long runs and stopping at gas stations.
can you guys help?? thanks!
72 GMC Camper Special 2500. currently has 350/350/14 bolt. 383 and 400 tranny is in the works. |
02-27-2004, 12:49 PM | #2 |
Ive thought about this too.... i know they make the poly tank kits to install in the spare tire opening under the bed, BUT I know that the general used to make a 31 gallon in blazers/jimmys and a 40 gallon for the burbs.... made me think i may be able to do something with one of those... dunno, but something to keep in mind, and even at 10 mpg youd still get a minimum of bout 280-300 miles b4 youd stop for petrol... just an idea...
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
02-27-2004, 01:03 PM | #3 |
Look around for some of the saddle tanks that guys are taking off. A good size rear tank, and the saddle tanks, and you should have some pretty good mileage range.
Keith 70 CST longbed in progress. Hoping to get it back on the road soon. |
02-27-2004, 01:24 PM | #4 |
Collector of Projects
Mark Fowler
aka FuelCellGuy www.aluminumfuelcell.com He can build you a custom tank. He has built a few for our trucks already... Thats who I'm going with when I get my 96 LT1 in the truck... |
02-27-2004, 11:07 PM | #5 |
I am a Referee of life.
Face it, your still young.If you was one of us old farts you would be making a "Pit Stop" before you needed gas even with the stock tank.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
02-28-2004, 12:04 AM | #6 |
JC Whitney use to sell bolt in replacements with extra capacity, 40+ plus if i remember right.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
02-28-2004, 02:16 AM | #7 |
Running on empty
I just ordered a 21 gallon metal "Blazer" version from Chevy Duty... cost me a couple hundred bucks. I can't wait to get the tank out of the cab, also, the extra fuel will be great. I have a BB in my truck so it does get a bit thirsty.
There are a couple of version of this type of implementation, 1) The OEM replacement metal tank 2) A thick polymer version that is about the same size. Each run about the same in expense, I suppose it is a matter of choice. Good luck.
thx, JDY |
