Old 02-27-2004, 08:13 PM   #1
Big69C20 Toy
Livin' it up.
Big69C20 Toy's Avatar
P/S swap...
Hey fellas, i was wondering what sorts of power steering setups you all run? I love the amazing EASE of my original '69 system but it's got leaks at the pump and the gearbox i think. Anyone know of seal kits or should i swap out the box and pump for something newer?
Is the swap out for a c20 from later years the same stuff? does it affect the ease of steering or anything? thanks much,
Greg
-Greg;
Sold the 69 C20. It's off to a better home with more love!
Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires.
Big69C20 Toy is offline   Reply With Quote
Old 02-28-2004, 01:25 AM   #2
Sweet72
Sweet72's Avatar
Why not just get a new pump and install in your old reservoir, get new press. and return lines. As for the gearbox, I can't remember who, but somebody sells seals for them. Maybe GearBox Grannie's.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 02-28-2004, 12:29 PM   #3
Hutch
Hutch's Avatar
Sweet72
I met these gut's at a local swapmeet.
They have been in business for quite a while and seem to know what these trucks very well.
http://www.powersteering.com/
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 02-28-2004, 12:47 PM   #4
minibike
minibike's Avatar
I bought seals at autozone. I used a 77 power steering box.
69 SWB
LT1/4L60E
www.classicplace.com
minibike is offline   Reply With Quote
Old 02-28-2004, 10:36 PM   #5
Mike C
Mike C's Avatar
Whether you get a rebuild or buy new (I would strongly consider new) get a variable ratio box and not a constant ratio. The original box is a constant and the variable will give you a much better road feel. You can buy aftermarket boxes with varying degrees of increased effort. I put an AGR rockcrawler box in my Jimmy, a constant ratio, and if I had to do it again, I would STILL get an AGR box, just the variable ratio. Two wheel drive boxes seldomly wear out like the 4x boxes, but an increased effort, variable fast ratio box will make your truck drive a TON better.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
