Old 02-27-2004, 09:47 PM   #1
our64
http://public.fotki.com/street
our64's Avatar
Mysterious master cylinder leak
I have a mid 80's chev dual MC on my truck . I totaly cleaned the outside and let the truck sit. Even with the level approx 3/16 from the top it seeps out from between the lid and body. I don't know how...Any thoughts. Besides seaking medical help
our64 is offline   Reply With Quote
Old 02-27-2004, 10:16 PM   #2
midyearvet@aol.
Leaky master cylinder
Either the rubber seal in the top is bad Or you still have it to full
midyearvet@aol. is offline   Reply With Quote
Old 02-28-2004, 12:18 AM   #3
cdowns
cdowns's Avatar
sometimes taking 200grit sandpaper and lightly sanding the top of the master will cure the problem
Old 02-28-2004, 01:22 AM   #4
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
my 79 had the same problem. I changed the cover gasket & the leak stopped. I got a good quality one from GM because I didnt want any hassles with a cheap offshore one.
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 02-29-2004, 10:10 PM   #5
1-PU70
1-PU70's Avatar
Try the fine sandpaper. I puy it on a small piece of 2x4. You will see the low spots fast. Use some paper towel to soak up the break fluid then stuf some in there to keep the dirt out.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
