Old 02-27-2004, 11:51 PM   #1
NORCAL_GUY73
NORCAL_GUY73's Avatar
Angry why won't my L.E.D's work????
Hey there guys,
Well I recieved my L.E.D. light conversion from Brothers and the damn things will not function properly. if I put the socket all the way into the socket hole the lights and turn them to secure them, they will not operate, if i pull it out slightly it will come on? Yet if I throw the 1157 bulb back in everything works like a champ. Enough to piss some one off after spending over a hundred bucks for brake lights... Does any one know a cure or have run into this problem, Please, please, please help...
thanks
Brad
NORCAL_GUY73 is offline   Reply With Quote
Old 02-28-2004, 12:14 AM   #2
cdowns
cdowns's Avatar
i think i read somewhere that you need a special type of blinker for leds
Old 02-28-2004, 12:15 AM   #3
dinnut
dinnut's Avatar
you probably need electronic flashers. most auto parts stores sell them
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 02-28-2004, 01:32 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Doesn't sound like he's having problems with the flasher, poor contact with the socket.
Try running some sand paper through the light socket on the ground portion (the portion that holds the side of the bilb) and then also ensure there is no corrosion or old grease on the contacts.
Old 02-28-2004, 02:34 AM   #5
68Custom
Hammer On!
68Custom's Avatar
I was having the same problem on my truck... i was told to wrap aluminum foil around the base of it to try for better contact. It did work sort of. I'm not exactly sure if the LED's i got were just junk to begin with, but to finish this out, I gave up on it.
Aaron
1968 C20
Inline 6 250
SM465 4 speed
1968 K10
Inline 6 250
SM465 4 speed
68Custom is offline   Reply With Quote
Old 02-28-2004, 03:10 AM   #6
FirstGen
Just Don't Stop!
FirstGen's Avatar
I'd be pissed. If it was me I would just solder them in and quit jacking with it... But you probably don't want to butch the harness I suppose.
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 02-28-2004, 03:15 AM   #7
krue
Designated A-hole!
krue's Avatar
Battery brush works well for cleaning light sockets. Unhook the battery cables first.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 02-28-2004, 06:27 AM   #8
A.P.
Black 72 Chevy
A.P.'s Avatar
I second with cleaning the sockets.
A.P.
72 Chevy, SWB, 350engine, TH400
A.P. is offline   Reply With Quote
Old 02-28-2004, 09:15 AM   #9
Longhorn Man
no need to disconnect the battery, just make d@mn sure your lights aren't on.
Old 02-28-2004, 12:29 PM   #10
Inthuwind
Straight jacket required
Inthuwind's Avatar
I don't know if this is relevant, but I put LED turnsignals on my Harley and they required an overload capacitor. Anyone else heard of this???
1968 C10 Short Stepper
350/350 A/C P/S P/B Front disc
3/5 static/ 12bolt rear 3:73
1979 Pontiac Trans Am
10th Anniversary/455/4spd
2011 H-D Street Glide - CAMMED n lowered
Dad always said,"Son, if you can't be good...be good at it."
Inthuwind is offline   Reply With Quote
Old 02-28-2004, 10:41 PM   #11
71elect
I agree with cleaning the sockets.
72Chevy swb 4x4
71GMC swb 2x4
71elect is offline   Reply With Quote
Old 02-29-2004, 01:40 AM   #12
Longhorn Man
Never heard of it. I have mine wired directly to the harness, an electronic flasher, and zero problems.
Old 02-29-2004, 03:05 AM   #13
NORCAL_GUY73
the part that stumps me is i can simply replace them with the original 1157 bulbs and they work perfectly. I will try cleaning the socket area again, but they appear non corroded. Does any one have the part number for the electronic flasher?
thanks
Old 02-29-2004, 01:16 PM   #14
neonlarry
neonlarry's Avatar
Just a long shot but those plugs for the LED's are special made items , check the clocking of the terminals vs the side locks compared to your std. 1157 bulb. Like I said a long shot but you never know.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 02-29-2004, 01:35 PM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
That's the first thing I thought of too. If the pins aren't clocked correctly you aren't making proper contact kinda like putting an 1156 or 1157 in backwards it may go in. but it won't come on...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-29-2004, 08:29 PM   #16
Andy4639
Old member
Andy4639's Avatar
Cool LED'S
I got mine for Christmas, and ran into the same problem. I ended up cutting some small sheet of thin metal I had and laying them in the sockets with the bulb plug to make it tighter fitting, haven't had no more problems with them, they work great.
I didn't use the electric flasher that came with mine though. The guy my wife talked to at Early Classic's said it wouldn't work without it, but it does. I still have the flasher in my shop.
Here is a picture of them after I got done.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-29-2004, 09:00 PM   #17
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Don't be in too big a hurry to "rag" on the LED's/seller until you are sure of the problem. If it is a defect, it can happen, you know they will make it good and work it all out with you.
These LED TLs are cool!...but you are working with a 30 year old vehicle. Try them in another vehicle/TL socket. Switch sides with the LEDs to see if it is the light or the socket.
You only need the electronic flasher if you have LEDs in both the front & back of vehicle. The front bulbs will make you normal flasher work, but it may be faster. If you want a slower, more deliberate flashing, then go ahead and put in the electonic...any auto parts store has them.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
