Old 02-28-2004, 08:50 AM   #1
BLUE80GMC
Power Sterring !!Help!!
I found my pressure hose was leaking so I went to auto zone & got a new one and had it installed and now it doesn' work at all. He did check the pressure relief valve to make sure he put it back in right. The pump was working fine before. Never had any problems with it except for the leak but it is the original pump, 80 model truck with over 100,000 miles. Any advice out there? The mechanic did say the new line could be stopped up where it was crimped together. I went and bought a remanuf pump just in case.
BLUE80GMC is offline   Reply With Quote
Old 02-28-2004, 09:57 AM   #2
MSL
MSL's Avatar
You have to bleed the pump sometimes also check fluid levels.
MSL is offline   Reply With Quote
Old 02-28-2004, 07:56 PM   #3
the baron
the baron's Avatar
How do you bleed the pump and the whole system ?
Just asking because I'm repairing my Burb with some pieces of my C-10 , and I had to put the C-10 "Hydro-boost" on the Burb , so i will have to bleed
Thanks...
the Baron
1982 Suburban 2WD , 260ci Olds engine,TH400 , will get a 1979 front clip , might be ready in ... 2016
1985 Chevy Van ( 305/350 ) , "Kellogg" equipped , my actual D.D.
1960 Girl Friend , frame still good , body has some dents
the baron is offline   Reply With Quote
Old 02-28-2004, 08:17 PM   #4
swervin ervin
You get what you pay for
swervin ervin's Avatar
To bleed the PS pump, you simply turn the wheel lock to lock, slowly. Making sure to keep it full on fluid.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 02-28-2004, 08:48 PM   #5
the baron
the baron's Avatar
lock to lock ?
you mean from full port to full starboard ?
and for the bleeding of the Hydro-Boost ? I saw that the main pressure goes to the hydro-Booste first and is then directed to the P.S. , when i turn the wheels , the hydro-Boost should automatically bleed itself , right ?
Thanks Ervin
the Baron
