Old 02-28-2004, 11:06 PM   #1
aggiedave98
tachometer suggestions?
Has anybody put an aftermarket tachometer on a cluster like my '89 suburban? It would be nice to have, but I'm not sure where to put it or where's a good place to get one.
aggiedave98 is offline   Reply With Quote
Old 03-01-2004, 01:41 PM   #2
cochino12
It followed me home?
cochino12's Avatar
you could try something like this
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 03-02-2004, 02:48 PM   #3
BigRed
I've got one that I still haven't installed. I'm going to strap mine to the column. It's an easy install and can easy be moved if needed. You can find many different options for tachs at http://SummitRacing.com . I bought mine there and it was only like $30.
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 03-11-2004, 12:20 PM   #4
IoWnZa
Big Block Blazer
I have a Factory Tach in mine, well sorta kinda but not really. The Cluster is out of an older truck, not sure the year, but it has the 5k Tach right next to the 100mph speedo. Prolly a late 70's cluster, I went this way cause it also has all real gauges, not dummy ones. like the Oil PSI, Voltage, and Temp.
[1985 Chevrolet K5 Blazer][454BBC][TH400][NP241][Dana 44][GM 12 Bolt w/ Eaton LSD][Hedman HTC Hedders][Dual 2.5" Stainless Steel Exhaust][Hedman Turbo Muffler's][Dual Spal's 14" Electric Fan's][32x11.50R15 BF Goodrich All Terrain TA KO's on 15x8 Rallys]
IoWnZa is offline   Reply With Quote
Old 03-18-2004, 03:46 PM   #5
ALASKA ALUMINUM BEAR
ALASKA ALUMINUM BEAR's Avatar
try auto meter
DEAR SIR
I am fussy over what tac to use so it's taken me years to find the right one....
in the end i went with a auto meter- mid range 4 inch-- in chrome and lighted...
i mount it just below my stero cluster with a slight turn towards the driver,,,,
It shows up very good day or night and costs about 70$---less in black...
hope this helps
ALASKAN ALUMINUM BEAR
IF YOU WANT I'LL SEND YOU THE PART NO FROM SUMMIT....LET ME KNOW
ALASKA ALUMINUM BEAR is offline   Reply With Quote
Old 03-26-2004, 02:04 AM   #6
sierrasports
BANNED
we offer a custom fit tach for a 89 suburban, goes right where it should bottom left of instrument panel.
$160 plus shipping , and we take paypal
a little wiring and disassembly required but if you want your interior to look seemless on this,
give us a shout
I-am-banned
sierrasports is offline   Reply With Quote
