Old 02-29-2004, 12:12 AM   #1
Robo_bot
Robo_bot's Avatar
Question How to pull glass?
Hey does anybody know how to pull the back glass out of a 69 GMC cab ????
Robo_bot is offline   Reply With Quote
Old 02-29-2004, 12:27 AM   #2
Martin64
Martin64's Avatar
.....I guess you're not looking for "a rock and a vacuum cleaner" as an answer....
Martin Gibson
USAF Retired
1964(-ish) C10
Martin64 is offline   Reply With Quote
Old 02-29-2004, 12:33 AM   #3
Robo_bot
Robo_bot's Avatar
no
Old 02-29-2004, 12:40 AM   #4
lukecp
Formerly yellow72custom
lukecp's Avatar
If you are buying a new gasket i would just slice the old one with a utility knife and carefully remove it.....if you want to re-use the gasket i can't help you
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 02-29-2004, 01:30 AM   #5
Dan72cst
Dan72cst's Avatar
I've had good luck prying the seal from the inside of the cab. Just do a little bit at a time and work the seal up and over the lip. I started in the bottom corner and went across the bottom first.
When I put it back in I slid the bottom in first and pryed the seal around the top corner. Works fine
Marysville, WA (Dan72cst@hotmail.com)
72 4wd Blazer CST 350/350
72 4wd Chevy LWB 350/350
68 2wd Chevy LWB 327/400
Dan72cst is offline   Reply With Quote
Old 03-01-2004, 03:45 PM   #6
Digger51
Starting at a bottom corner is key.
70 GMC, SWB, 2WD, low
Digger51 is offline   Reply With Quote
Old 03-01-2004, 05:59 PM   #7
spencra
This, is my BOOMSTICK!
spencra's Avatar
I agree with yellow72custom. I just pulled both windshield and rear window a a couple of weeks ago. I just took the old leatherman and worked it underneath the seal and pushed it all the way through and just sliced down and out. This will leave you with a nice little flap to grab onto. I used a pair of pliers to grab onto the flap at first as it is hard t get a good grip. When you get a good few inches you can just pull on it by hand. Depending on how rotted the seal is you can usually pull off a good part of it that way. I had to go through the steps a couple of times. When you get most of it off you can usually pry the window out (carefully).
Hope this is helpful.
Larry
Got rid of my projects for now.
1980 Jeep CJ7
1998 Nissan Sentra (my car)
2001 Toyota Sienna (wife's, of course)
spencra is offline   Reply With Quote
