02-29-2004, 03:41 AM | #1 |
Suburban Rear End Questions
Did some searching, but couldn't find the answers, so I'll just ask...
I have a '72 C10 350/350 (2wd, 5 lug) suburban with no listed rear end option on the glove box sheet. I have a '70 C20 350/ 4 speed (2wd, 8 lug) suburban with "no slip rear end" on the glove box sheet. My questions are..... 1) What would the gear ratios be for each 'burb? 2) Does the "no slip" mean it's a Detroit locker? 3) Are these interchangable? 4) What differance would it make if they are interchangable? I should also mention that it is the '72 that I am currently restoring. I'm thinking no slip would be good for the '72, cause who want to see just one black mark on the pavement!!
1972 Chevrolet Suburban ('68 front clip), 2wd, 350/350, factory tilt 2008 Kawasaki Concours 14 1997 Harley-Davidson Soft Tail Custom 1948 Chevrolet Coupe (project) 1972 Porsche 914 |
02-29-2004, 09:42 AM | #2 |
The 1/2 ton with a 350 would have come with 3.07 gears. Are you sure it doesn't say no-spin? That would be a Detroit Locker. I would also guess that the '70 has an Eaton with 4.10 gears - also could be 4.56.
Tim Last edited by Blazer1970; 02-29-2004 at 09:44 AM. |
02-29-2004, 10:37 PM | #3 |
Thanks Blazer1970........anyone else have the info I'm trying to get, or know where I could look?
02-29-2004, 11:19 PM | #4 |
Formerly yellow72custom
If they are both coil spring rear ends i think they will interchange. However you would have 5 lugs on the front and 8 lugs on the back.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
03-01-2004, 12:28 AM | #5 |
I was thinking of swapping just the locker and gears if that was possible, or just the locker, not the entire housing and everything, although they are both coil spring trucks and it did momentarily cross my mind!!
03-01-2004, 01:04 AM | #6 |
The internals are completely different and won't swap out.
03-01-2004, 01:42 AM | #7 |
Thanks man, appreciate the help.
