Old 02-29-2004, 01:35 PM   #1
stan79chevy
stan79chevy's Avatar
3/4 ton gear ratio?
im buying a 79 3/4 ton for teh axles to put under mine when i get it all back toghther.
the truck came wiht a 292 6cylinder 3speed and a 205 t case..the guy im buying it from says he thinks they are 3.42 or 3.56 gears but he cant remember, my brother in law says with a 6 cylinder 4x4 3/4 ton they would have to be 4.56 or 4.10.. any one know off hand wich they might be either way its better than the 3.08 crap i have now.
thanks
stan
79 chevy k20 350/350/205/D44/14bFF
4.56 gears rock
LWB pimer black
01 S-10 ZR2 extended cab
4.3/4L60E/233
3.73 gear 31" DICK CEPEK CRUSHERS
stan79chevy is offline   Reply With Quote
Old 02-29-2004, 01:37 PM   #2
stan79chevy
the front axle is an 8 lug gm 10 bolt the rear is a 14 bolt full floater if that helps
stan
4.56 gears rock
LWB pimer black
4.3/4L60E/233
Old 02-29-2004, 02:15 PM   #3
ALBATROSS
Irecently picked up 3/4 ton axles for my truck a nd my 14blt. ff had 4.10 but i dont know what truck they came out of I just picked from a pile. I'm not sure about yours. I would say 4.10 because I think that most of them came with that gear. you can divide the # of ring gear teeth by the pinoin teeth or vice versa and figure it out that way. By the way does it have the removable pinoin? That would make it easy to count the pinion gears.
ALBATROSS is offline   Reply With Quote
Old 03-01-2004, 11:18 AM   #4
2wdBlazer
The Blazer King
2wdBlazer's Avatar
My FF rear has 3:73. It sucks.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 03-01-2004, 01:14 PM   #5
LeRoy
Registered truck nut
LeRoy's Avatar
I'd bet they're 4.11's but could be 4.56
MOUNT VERNON, WASH. STATE
Need a part? Just PM me
LeRoy is offline   Reply With Quote
Old 03-01-2004, 09:18 PM   #6
1FaastC10
1FaastC10's Avatar
4.10s are most common, but 4.56s arent out of the question. 3.73s are extremely rare.
1FaastC10 is offline   Reply With Quote
Old 03-02-2004, 02:02 AM   #7
Scrub
Collector of rusty Items
Scrub's Avatar
Hmm.... I have bought at least 4 corp-14 axles out of a junk yard and they were all 3.73's. Maybe it's a regional thing. I run 165 r70 16 tires (I might be off on the r70 part) and I really like that ratio with stock tires.
What is common? I suppose that 3.42 or 3.56 axles would be more widely acceptable in the midwest and such where you don't have as many hills to climb.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
