Old 02-29-2004, 01:43 PM   #1
roadking
auto shifter has a grinding feeling when cold?
when i shift truck into gear when cold i can feel sortof a light bad bearing grind, shifts fine when warm ?, i repalced both lower and upper bearing in my steering colum ( non-tilt 71). does the tightness off the spring hold up bolt have any effect on the shifting into gear? i lubed everything up good while i had apart. anyone had a similer problem? THANKS
71 C10 SWB
BLACK AND WHITE
350 CRATE TH350
ENJOY LIFE
roadking is offline   Reply With Quote
