Old 02-29-2004, 03:00 PM   #1
wyoman64
wyoman64's Avatar
Unhappy Bad News
Hey All,
I just took my new '69 K20 out for it's first real spin in 4WD and discovered a couple of problems and need some help figuring out what kind of costly repairs I can expect:
Problem 1: While driving in 4WD I get an intermittent bind somewhere in the front axle or hubs. It makes a really sickening "klunk" sound and it'll snap your head forward. I have Spicer hubs and it is very cold out. Could this be a hub not fully engaged?
Problem 2: While inspecting the front end I discovered that my right font spindle and hub assembly has some play in it where it attaches to the axle flange. (See the attached photo, area where there is play is indicated by the red arrow) There's probably 1/16" of slop there, what is involved in fixing this? Is the spindle/wheel bearing nut loose? Or, does the backing plate bolt to the axle flange?
Could the two problems be related?
Sorry for the dumb questions, but I'm new at this . . .any help appreciated.
1969 Chevy K20 Fleetside
1979 Chevy K10 "ROBAHOR"
(Rusted Out Beyond All Hope Of Repair)
wyoman64 is offline   Reply With Quote
Old 02-29-2004, 03:13 PM   #2
barn9
Half a bubble off!
barn9's Avatar
You might get a quicker answer to this over at the 4x4 section, and change the title to something like "Front end question", or "Need help question". I'm sure someone can answer your questions. Is the binding happening while turning, or all the time?
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 02-29-2004, 04:36 PM   #3
too much stuff
Roadtrip!
too much stuff's Avatar
for question 1 it kinda sounds like a bad axle joint. If you jack up the front end, engage the hubs, and turn the steering wheel all the way to one side, then spin the tire by hand. You should know right away if that is it.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
