Old 02-29-2004, 04:34 PM   #1
Trucks
Is that a Chevy 69...?
need driveline parts
Hi, I bought a 68 GMC 3/4 ton 4x4 with a messed up rear end, when I get over 35mph it makes a nasty grinding noise. Also its 4.56 in back and 4.55 in front, too low for me. SO I figured If I replace both the front and rear with something not so "granny" I can at least do 65 mph I'd be happy. Do you have a diff that will work for me? The truck has leaf springs and I have swapped a whole tube before but not just the rearend. I have not done a front swap at all. Any help would be great!
Also Its second gear wont enguage, synchro ring? Should I repair it or replace it?
If I lifted it the cheapest way, and put say, 32" tires on could I go any faster? I could just replace the rear, same gears if I got big enough tires maybe. I'm in brownton MN
Ahhhh, the wonderful sound of a rumbling V8.
Trucks is offline   Reply With Quote
Old 02-29-2004, 07:28 PM   #2
Bowtie67
Bowtie67's Avatar
Post
That would be a type4 carrier and you can drop gears down to 3.73 which wouldnt be that expensive just time consuming unless you have someone else do it. not sure what to do about trans, I would rebuild i myself but these can get pricey having some one else do it so it might be cheaper to swapout. JMO
Bowtie67 is offline   Reply With Quote
