Old 02-29-2004, 04:58 PM   #1
wyoman64
wyoman64's Avatar
Question Front Axle Problem
Hey All,
I just took my new '69 K20 out for it's first real spin in 4WD and discovered a couple of problems and need some help figuring out what kind of costly repairs I can expect:
Problem 1: While driving in 4WD I get an intermittent bind somewhere in the front axle or hubs. It makes a really sickening "klunk" sound and it'll snap your head forward. I have Spicer hubs and it is very cold out. Could this be a hub not fully engaged?
Problem 2: While inspecting the front end I discovered that my right font spindle and hub assembly has some play in it where it attaches to the axle flange. (See the attached photo, area where there is play is indicated by the red arrow) There's probably 1/16" of slop there, what is involved in fixing this? Is the spindle/wheel bearing nut loose? Or, does the backing plate bolt to the axle flange?
Could the two problems be related?
Sorry for the dumb questions, but I'm new at this . . .any help appreciated.
1969 Chevy K20 Fleetside
1979 Chevy K10 "ROBAHOR"
(Rusted Out Beyond All Hope Of Repair)
wyoman64 is offline   Reply With Quote
Old 02-29-2004, 05:40 PM   #2
drink2mny
drink2mny's Avatar
As for the spindle being loose, you will need to take the hub off and the rotor to get to the spindle bolts.
And the clunking or binding may be involed with that problem with your axle hitting or having the spindle loose..
you would be amazed what a 1/16 can do to screw up a frontend..
As for a silly question also for the binding did the noise/clink come from your transfercase..
I have seen where 2 different gear ratio's in the front and back causing the transfer case to bind on hard dirt or pavement.. You usually won't get a bind in mud or snow..
Support The Board
drink2mny is offline   Reply With Quote
Old 02-29-2004, 10:34 PM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
No rotor has drums. But the backing plate will come off w/ the spindle.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 03-02-2004, 02:09 AM   #4
Scrub
Collector of rusty Items
Scrub's Avatar
Hmmm...
I am thinking maybe you have something in the drum that is hanging up, or maybe a broken keeper. If the shoes flop around, they can catch on the side of the drum and really make a bad noise, not to mention a big clunk. I say pull the drums off and have a peek inside before you drive the kids anywhere.
Good luck
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 03-02-2004, 03:01 PM   #5
wyoman64
wyoman64's Avatar
Thanks Scrub, it only does it when it's in 4WD though, but I agree, I need to have a look-see inside.
Old 03-07-2004, 06:51 AM   #6
ZOOMY
clunk
I had a roller in a wheel bearing do that once. The roller was disintegrating a little bit at a time. The little piece would then get crushed in the rest of the bearing as it went thru.
ZOOMY is offline   Reply With Quote
