Old 02-29-2004, 10:55 PM   #1
purple69
purple69's Avatar
gas guage
got power at gauge still not working any suggestions
purple69 is offline   Reply With Quote
Old 02-29-2004, 11:14 PM   #2
jorgensensc
jorgensensc's Avatar
Make sure you have a good ground. The stud that does not mount to the circuit card should be grounded to the gauge cluster. I would try and run a wire from that stud to a good gound elsewhere, since the gauge cluster doesn't always ground too good.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 02-29-2004, 11:16 PM   #3
jmanz69
Careful, they attack...
jmanz69's Avatar
Check the ground on the gauge, also check the wire going from the sending unit. If you have a meter, check it for continuity. I have a new gauge if you need one also. Mine have all been tested and are known to work. If you check from the sending unit wire to ground, you should have between 0 and 100 ohms depending on how much gas you have in the tank. If you don't, then your sending unit could be bad. Take it out and check to see if the float has filled with gas and is sitting at the bottom.
jmanz69 is offline   Reply With Quote
Old 02-29-2004, 11:43 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Where is your needle pointing? This will tell you where to look for the problem.
Old 02-29-2004, 11:47 PM   #5
purple69
purple69's Avatar
its pointing at 1/8 tank
Old 03-01-2004, 12:50 AM   #6
jhow66
jhow66's Avatar
Hey purple69 check out new thread--"gas gauge fixed!!"-- might help you out.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
