03-01-2004, 12:58 PM | #1 |
WTB Accelerator *cable* pedal assy
First off I have a 68 with a gas pedal rod and linkage. I want to convert to the cable style. Will this work with some modifications? Was 72 the only year for these.
And oh yea I would like the whole assembly. Thanks Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" Last edited by Custom 68; 03-01-2004 at 03:00 PM. |
03-01-2004, 01:14 PM | #2 |
Dave,
My '71 Blazer has a cable linkage as well. I was able to find a replacement cable (pedal to carb) from Sallee Chevy. On the carb end you'll still need to get a linkage bracket, but those are a dime a dozen. Not sure what you'll need to change on the pedal end. Perhaps someone else can help with that. Brian |
03-01-2004, 01:27 PM | #3 |
Pesemistic Optimist
Ditto on the cable, picked one up from my local Chevy dealer for like $15.00.
Dan. |
03-01-2004, 03:53 PM | #4 |
Location: Katy, TX...but the love of my life resides in Dublin,OH.
the pedal is different also. I'm not sure if the the rod style pedal can be adapted. I took the pedal assembly out of a 72 and fabbed up a small bracket to bolt it to. The pedal rod style bolts to the firewall in the engine comp. the cable style bolts to the firewall inside the cab. And what would've been nice if they had the same bolt patterns, but they dont. My bracket bolts to the firewall inside the cab into the holes that are there for the rod style, and the the cable pedal is bolted to the bracket.
03-01-2004, 04:03 PM | #5 |
Thanks guys Yea I am looking for the entire assembly. I currently have a lead on one. He is going to check it out tonight and let me know. My message may hae been a bit confusing I was looking for everything not just the cable.
Thanks again Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
03-01-2004, 04:20 PM | #6 |
I have a 72 parts truck. I dont remeber what kind it was but I can check tonight.
69k5 |
03-01-2004, 06:58 PM | #7 |
I have the complete set up if your lead doesn't come thru. Let me know.
