Old 03-01-2004, 02:36 PM   #1
grovmister
Question Rear Disk for Chevy 12 Bolt Rear
I am considering upgrading to Rear Disks utilizing 79-81 Cad Calipers. I am wondering if anyone knows where I can get the mounting Brackets, and if there are any stock disks available which would not require turning of the axles.
Any suggestions on this and any other issues associated with the swap would be of great interest.
Thanks, Mike
72 Chevy C10 LWB 15X8 Chevy Corvette style rallys.
72 Chevy C10 LWB Truck Ralleys, tach, tilt, hidden hitch
72 Chevy Grn C20 Custom Camper 120K Newer Style Truck Alloys, Dailey Driver.
grovmister is offline   Reply With Quote
Old 03-01-2004, 08:23 PM   #2
jbw0127
I used a Speedway Motors kit. The brackets were the weld on type and the rotors hats had to be turned to fit over the hub. I know bolt on is easier but I saved a couple hundred bucks with this kit. If I remember correctly, it was about $400.
72 swb Cheyenne
"nut & bolt" frame off (in process)
Blown 383
jbw0127 is offline   Reply With Quote
Old 03-05-2004, 03:38 AM   #3
67shortie
Green club
67shortie's Avatar
That looks awsome jbw! I would love to see that when it gets bolted together
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 03-05-2004, 02:40 PM   #4
78k10383
i saw this only $185 for the kit, but u have to buy calibers.
http://coloradok5.com/atrondiskbrakes.shtml
78k10383 is offline   Reply With Quote
Old 03-12-2004, 06:13 PM   #5
mcmlxix
Collector of Projects
mcmlxix's Avatar
POST
Rich
1972 K5 Blazer CST Click HERE
Old 03-14-2004, 01:08 PM   #6
Slammed67
Progress = 0%
Slammed67's Avatar
In my opinion, that isn't a very well designed caliper bracket. Notice how it positions the caliper so that the bleeder screw is in a horizontal position. It should be postioned so it is pointing upwards so that the caliper can be bled properly. I would think it'd be nearly impossible to get all the air out of that caliper since there would be air space above the bleeder screw.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 03-19-2004, 12:38 AM   #7
Low69CST
I don't like this kit for another reason. The plate caliper bracket doesn't provide enough support for the caliper. The caliper bolts are supposed to go all the way though to the wholes on the outer holes of the calipers. Then the spindle on the front should have fingers that come out and run along the top of the caliper for support. To me that looks like it would twist and cause poor braking and pad wear.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 03-19-2004, 01:24 AM   #8
PTS Kustoms
Rear disc kits are very over rated. Check out ECE's rear drum upgrade kit.
PTS Kustoms is offline   Reply With Quote
Old 03-19-2004, 11:06 AM   #9
Slammed67
Progress = 0%
Slammed67's Avatar
I agree. They look cool though
