Old 03-01-2004, 07:35 PM   #1
dinnut
dinnut's Avatar
Question posi?
my main question: do i have a posi/limited slip rear end. i have a stone drive way so spinnign the tires is very easy. today i uh "accidentally" floored. this was after backing up and pulling forward a couple times. went behind the truck and both wheels had spun! usually on the right wheel spins! i might have to try it again later just to see if it does it again! the truck seemed like it was twisting when i held on the throttle for a second. is it possible that only both engage sometimes??? and usually on the right engages. i know the only real way to know is to pull the rear diff cover and find out but too lazy right and know and was just wanting some of yalls input. the previous owner said this rear was swapped in because the other rear end wasnt very highway friendly. and i was going to maybe swap in the rear end out of my 72 which is not a posi and im hoping the 70 has the wider rear now so i dotn have to swap the whole setup, just the axles!
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 03-01-2004, 07:40 PM   #2
1969 GMC
1969 GMC's Avatar
i'm guessing that you don't. open diff axles can still spin both axleshafts if they are both getting just about the same amount of traction, which would probably only happen in a loose terrain (like your gravel driveway, sand, mud, etc.)
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 03-01-2004, 08:17 PM   #3
c10crazy
Like a Rock!
c10crazy's Avatar
I would hold the brake hard and give it full throttle. You should see 2 marks. I think if you jack the rear up and spin the tire by hand , they should both spin in the same direction. Not sure though.
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 03-01-2004, 08:42 PM   #4
lukecp
Formerly yellow72custom
lukecp's Avatar
c10crazy is correct
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 03-01-2004, 11:18 PM   #5
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Only problem with holding the brake and doint it the brake tricks the rear into thinking both tires have the samp amount of traction. I've done this is a truck that I know has an open rear and it acted like a posi...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 03-01-2004, 11:36 PM   #6
dinnut
dinnut's Avatar
eh i dont really have my hopes up, but ill be testing it soon to see if it is a posi
70 longbed
496/th400/Ford 9"
Old 03-02-2004, 03:54 AM   #7
1969 GMC
1969 GMC's Avatar
sure-fire way to check is to pop the diff cover...heck, gear oil is cheap and you probably need some new anyways.
1969 GMC K2500
1996 Honda Accord
Old 03-02-2004, 05:56 AM   #8
MandarinSixSeven
Seasonal Poster
MandarinSixSeven's Avatar
jack up the rear end and spin one wheel, if they both spin the same way it's a posi or limited slip, if they spin opposite, its an open diff, just like c10 said
67 GMC Short Step
350/4-Speed/3.08 Posi
Front/Rear Sway Bars
Kelowna BC, Canada
Member of DTPW
MandarinSixSeven is offline   Reply With Quote
Old 03-02-2004, 09:40 AM   #9
Bowtie67
Bowtie67's Avatar
Post
Jack up one side if you can turn wheel it's not a posi..
Bowtie67 is offline   Reply With Quote
Old 03-03-2004, 01:37 AM   #10
Rod
a posi could still spin only one tire if other was on the ground still.. best to get both tires in the air at same time and then spin a tire and wait to see if other spins in same direction. Still if you think its possible, I would still pull the cover and make sure....stuff wears out.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 03-03-2004, 03:28 AM   #11
Sweet72
Sweet72's Avatar
Yep, only way to know for sure is to pull the cover. If the clutches and springs are worn in a posi it will act like an open diff. Have you checked the glove box door to see if it was and option?
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 03-03-2004, 11:14 AM   #12
AndrewDT
AndrewDT's Avatar
What if you park with one tire on gravel and one on the pavement? If the gravel side spins it's... Open? If they both spin it's... Posi? If neither spin... You need more horsepower!
'72 Suburban 4X4
"Save the Earth, kill yourself"
AndrewDT is offline   Reply With Quote
