Old 03-02-2004, 12:19 AM   #1
69Custom
69Custom's Avatar
LS1 gas tank options
I am going to do a 5.3L LS1 swap next month and would like to find the best option for my gas tank. I want to put in under the bed and preferably have the fuel pump in the tank. I would like to know that what some others on the board have done with their fuel injection. Also for the ones that have a 4l60e transmission, what type of shifters are you using (pictures greatly appreciated)
Jerr
Also I will take picts of the swap and post them if there is any interest.
1972 Chevy C-10 Short Stepside
6Cyl, 3 spd, not opts
(Current Project)
Now a 2004 SSR 5.3L with 4L60E
Now Ididit tilt- ps, pb
2002 Saturn L200
2006 Toyota Highlander HYBRID
69Custom is offline   Reply With Quote
Old 03-02-2004, 01:21 AM   #2
stepside71
Project Money Pit
What I am doing is going with a tank out of an 89 Impala. It had tbi fuel injection with the pump in the tank. I will be welding 3 inch space bars under the frame. I will then cut out a hole behind where the tag will go. Don't forget the folddown tag hinge. The gas tank neck will be shortened and fitted to be right behind the tag by using a piece of rubber hose .BTW I am using a tbi system out of an 89 van.
For sale: GMC rad support $50, L/F 69-72 fender $50, (1) 69-72 & 67-68 Chevy hood $50 ea.,1 disc brake spindles w/ calipers and rotors $ 25
WTB: (1) R/F inner fender. OR will trade
stepside71 is offline   Reply With Quote
Old 03-02-2004, 02:27 AM   #3
Richard
Later model Blazer tank will work, though a higher pressure pump will be needed as TBI is only around 15psi I believe. I think 89-93? Mine is from a 90.
The stock linkage will work for the four speed, a little clearancing needs to be done to get it all the way into first. The guy I got my rebuilt tilt column from at the Pomona swap meet gave me a re-lettered indicator lens with the column. The lettering is a little big so I plan on redoing it with a bit of scanning, image manipulation and printing on decal media.
Richard
Old 03-02-2004, 02:31 AM   #4
gonebad2
Merciless Butcher
gonebad2's Avatar
As far as the tank goes, contact board member fuellcellguy. He can hook you up with what you need.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 03-02-2004, 10:23 PM   #5
Vince M
Vince M's Avatar
I think I'm going to stay with the in cab tank and put a inline external pump in the frame rail. Your pump needs close to 60psi for the LS1. I don't want to give up my spare tire mount. You'll lose it if you go with the under bed tank.
68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements.
Vince M is offline   Reply With Quote
Old 03-09-2004, 11:11 PM   #6
incoma
incoma's Avatar
I'm also going to opt for the frame mounted pump. A tank mounted pump would be great, so we could reuse our lines, but it seems like its too much of a hassle to get one in there.
incoma is offline   Reply With Quote
Old 03-09-2004, 11:22 PM   #7
crazy4chevs
crazy4chevs's Avatar
can't help but would like to see updates and pics.
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
Old 03-09-2004, 11:27 PM   #8
bigbluthng
bigbluthng's Avatar
yesterday i saw a 68 FORD shortbed fleetside with a 5.3L VORTEC!! and 4L60e!!! he was using his factory fuel tank with an external pump, although he did have a tank from an 01 truck in the bed that he was going to throw on.
bigbluthng is offline   Reply With Quote
