Old 03-02-2004, 12:59 AM   #1
ucmydust68
fuel
air line question????
ok so i have the bags all in and i was putting the airlines in and i was wondering how yall run yours in the front? it seems the only way is to run them out the hole in the bottom of the crossmember, but doesnt that put the lines in danger of hitting something?? i was thinking about drilling a hole in the rear of the crossmember and just running it out the hole. any ideas would be great!!
thanks
72 w/67 front clip
415ci
fuel injection
t56
air ride
18/20's
ucmydust68 is offline   Reply With Quote
Old 03-02-2004, 01:34 PM   #2
rigo
Flake Daddy
rigo's Avatar
you can run a line out anywhere you want....but if there's any change of the hose touching a metal edge...then use a grommet.
1968 SWB Fleet Daily Driver 350/TH400 shaved driprail,emblems,tailgate,air ride suspension
1964 Pontiac Catalina 2dr. hardtop shaved everything, air ride suspension
1998 Range Rover
1960 El Camino....in the works.....
rigo is offline   Reply With Quote
Old 03-03-2004, 07:55 PM   #3
NORCAL_GUY73
NORCAL_GUY73's Avatar
I suggest if you have the air line entering the top of the bag, it will be concealed in the upper spring cup. What I did was drill an adequite hole in the upper area of the cross member, use a grommet and run the line up over the frame rail and then lead it to where ever your air tank is located. I have had mine this way for a year will regular driving and no problems...
NORCAL_GUY73 is offline   Reply With Quote
Old 03-03-2004, 10:26 PM   #4
Izzy
Trucker.
Izzy's Avatar
That sounds perfect.
Izzy is offline   Reply With Quote
