Old 04-01-2002, 06:44 PM   #1
mstacy
mstacy's Avatar
Post Need A/C relay help
The service manual shows an anti-dieseling relay that should be plugged into the a/c wiring harness under the dash. This is not the one over by the glove box/ right kick panel area. This one plugs in around the center controls, behind the dash. Does anyone have one of these or know the GM part number? I can't seem to find any and the blower won't work without it. The circuit isn't complete I guess. Thanks!
Mike Stacy, S. Calif.
1971 Factory Hugger Orange Shortbed, 350/350, 20" Torq Thrusts, 3/5 drop (belongs to my son Christopher now) I am looking for a rustfree loaded 71-72 Burb.
mstacy is offline   Reply With Quote
Old 04-01-2002, 06:56 PM   #2
71Chev
71Chev's Avatar
Post
Sounds like your high speed fan relay or fan switch is shot.
I have my anti-dieseling relay unhooked and my blower works fine.
Have you checked the relay inside the heater box?
[This message has been edited by 71Chev (edited April 01, 2002).]
71 Chevy CST Long Fleet 350/350/3.07 leaf rear.
71Chev is offline   Reply With Quote
Old 04-01-2002, 07:14 PM   #3
71Chev
71Chev's Avatar
Post
To check the relay inside the plenum there is a small vent on the bottom of the box near passengers left foot in the cab. Pull it open or if already open squeeze the sides so the small vent pops out. Look up in that square hole, you'll see the relay. It has a smaller coil and a larger coil. If one is burnt you'll be able to tell.
Old 04-01-2002, 11:21 PM   #4
mstacy
mstacy's Avatar
Post
Everything is pretty much new. The wiring harness is a new replacement from Brother's. I did use a jumper on the 3 prong pigtail where I think the anti-diesel relay plugs into and the fan worked. That makes me think something needs to plug into the pigtail, like a relay or something in order to work. Any suggestions are appreciated.
Old 04-02-2002, 12:10 AM   #5
Hutch
Hutch's Avatar
Question
I just went over my whole factory a/c system.
Where is the pigtale you are referring to located?
What color are the wires?
You did say that the highspeed relay by the kick panel is good.
John Hutchison
Grapevine,Texas
76051
71 1/2 ton swb 307 pg
69 Jaguar XK-E 4.2 Roadster
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 04-02-2002, 12:35 AM   #6
Hutch
Hutch's Avatar
Post
The one I have is a Delco Remy 811-12V and mounts under the dash between the radio and glove box and grounds to the lower lip of the dash. It has three prongs,
The description in LMC's catalog list it as Relay a/c Blower $14.95
John Hutchison
Grapevine,Texas
76051
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Old 04-02-2002, 01:16 AM   #7
mstacy
mstacy's Avatar
Post
Hutch, that's the one. I guess it's the high blower relay then and not anti-dieseling. I guess that makes sense why it doesn't work!! It's alway the simple things that gets ya. Thanks for your help. I see the relay in LMC.
Old 04-02-2002, 08:56 AM   #8
71Chev
71Chev's Avatar
Post
That relay Hutch is talking about is the one I have unhooked. My fan wouldn't run on High just on low and med. Until I unpluged that relay, I guess since the anit-dieseling relayisn't hooked up under the hood. My harnesses are uncut original. The anti diesleling relay is mounted to the bottom lip of the dash. Number 16 in LMC has four prongs, and is the highspeed fan relay that mounts near the pass. fresh air vent on the plenum. The other relay is inside the plenum.
Old 04-02-2002, 10:15 AM   #9
mstacy
mstacy's Avatar
Post
THe one in LMC #16 has 4 prongs doesn't it. My pigtail only has 3. I don't have any other relays other than the ones already mentioned. The one is LMC looks more like the one over on the passenger side by the plenum. I don't have one under the hood that I can remember. Where is your located?
The other one located inside the A/C box in the interior, is actually a resistor. That's the one with the wire coils. That also looks good.
When I jumper the pongs on the anti-diesel relay, the blower works which leads me to think that is the problem. Now I am lost! Any ideas?
Old 04-02-2002, 10:53 AM   #10
71Chev
71Chev's Avatar
Post
That's the high speed fan relay you see in the LMC catalog and yes it does have 4 prongs.
My fan works great now that I unplugged the anti-dieseling realy. (one on the dash lip)
I'm stumped. Have you tried bypassing the high speed relay with jumper wires in the plug? with and w/o the dieseling relay hooked up?
I guess I'd replace the high speed fan relay. You might be able to get it at your local parts house.
[This message has been edited by 71Chev (edited April 02, 2002).]
Old 04-02-2002, 12:40 PM   #11
Hutch
Hutch's Avatar
Post
When my high speed fan relay was on the fritz(broken ground wire) the symptons were:
when the three speed switch on the a/c control was on low and medium it worked ok but switch to high it would go back to low.
I was troubleshooting the circuit when I accidentaly grounded the case of the relay. With the fan switch being in the high
position the blower increased substantualy in rpm's
Pay special attention to your ground leads. The high speed relay on near the kick panel has a black lead whick is attached to the firewall and the one on the dash lip is grounded through a screw to the case of the relay.
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Old 04-02-2002, 01:06 PM   #12
mstacy
mstacy's Avatar
Post
My truck didn't have A/C originally, I added it a piece at a time using mostly new or NOS pieces. I don't remember seeing a black ground wire for the relay. The new harness had wires for all prongs of the relay but no seperate black ground wire. I used 2 screws and secured it to the firewall area which should be a good ground anyway. This has got me miffed.
Old 04-02-2002, 06:09 PM   #13
mstacy
mstacy's Avatar
Post
71 Chev and Hutch....THANKS!! It was the relay afterall. I replaced it with another one and it works great. I tried that the other day and got nothing, so I am not sure what really fixed what, but it works and that's all that matters.
Old 04-02-2002, 06:13 PM   #14
71Chev
71Chev's Avatar
Thumbs up
Good deal!
